Home » Language IDEs » Java Development Tools (JDT) » Increase the Eclipse content assist size
Increase the Eclipse content assist size [message #259359] Mon, 06 April 2009 10:45 Go to next message
Originally posted by: adieuspam.free.fr
Hi everyone,
I've seen someone à the Paris JUG whose eclipse's content assist was
pretty large. Since I also use a wide screen, I started searching where
this configuration was in Eclipse. Whitout success.
Does someone know how to increase the size (precisely, the width) of the
popup window that appears for content assist (CTRL + SPACE), and also
how to increase the size of the javadoc popup window that appears
normally on the right of the first one.
Bonus question : the guy i saw with this configuration also managed to
place the javadoc popup window under the content assist popup window
(normally it's on the right). Does anyone know how to do this too ?
PS: some previous research on google pointed out some folks saying that
rezising these window popups causes eclipse to remember the new size
forever, but as many others, it doesn't work at all for me.
regards,
Waddle
Re: Increase the Eclipse content assist size [message #259362 is a reply to message #259359] Mon, 06 April 2009 11:50 Go to previous messageGo to next message
Philippe De Oliveira wrote:
> Hi everyone,
> where this configuration was in Eclipse. Whitout success.
> the popup window that appears for content assist (CTRL + SPACE), and
> also how to increase the size of the javadoc popup window that appears
> that rezising these window popups causes eclipse to remember the new
> size forever, but as many others, it doesn't work at all for me.
This is how it is supposed to work, except for Linux where you don't get
the resize handle. The Javadoc window gets the same size as the proposal
popup and if the space on the right is too small then the Javadoc window
is placed below. There are no preferences for this.
Dani
> regards,
Re: Increase the Eclipse content assist size [message #259364 is a reply to message #259362] Mon, 06 April 2009 13:07 Go to previous messageGo to next message
>> Hi everyone,
I just tested this feature on Mac OS X and it worked just fine. You are
right, I am working on a Linux platform and i don't have any resize handle.
It's too bad for Linux (which is the best development platform by the
way :-p)
Thanks anyway, I am going to open a bug about this.
regards,
Waddle
Re: Increase the Eclipse content assist size [message #259367 is a reply to message #259364] Mon, 06 April 2009 13:17 Go to previous messageGo to next message
>>> Hi everyone,
>>> appears normally on the right of the first one.
>>> to place the javadoc popup window under the content assist popup
>>> window (normally it's on the right). Does anyone know how to do this
>>> too ?
>> get the resize handle. The Javadoc window gets the same size as the
>> proposal popup and if the space on the right is too small then the
>> Javadoc window is placed below. There are no preferences for this.
> way :-p)
FYI :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=271347
Waddle
Re: Increase the Eclipse content assist size [message #259383 is a reply to message #259367] Tue, 07 April 2009 08:03 Go to previous message
>>>> Hi everyone,
>>>> too ?
>> are right, I am working on a Linux platform and i don't have any
>> resize handle.
>> way :-p)
> FYI :
I just want to give a workarround for this bug. I resized the content
assist popup window on a Mac OS X and then get the piece of XML written
by eclipse in order to save the new size.
By setting this piece of XML into an Linux installation of Eclipse, you
get the same result.
The XML to change is :
${myWorkspaceDir}/.metadata/.plugins/org.eclipse.jdt.ui/dial og_settings.xml
Add this section (be carefull, it might already exist but it's then
sould be empty) :
<section name="completion_proposal_size">
<item value="800" key="size.x"/>
<item value="300" key="size.y"/>
</section>
You can of course change the values.
regards
Waddle
Previous Topic:externalized strings : conver to 'eclipse mechanism'
Next Topic:refactoring a group of constants in enum
Current Time: Thu Nov 06 00:53:11 EST 2025
Powered by FUDForum. Page generated in 0.04132 seconds
