Home » Archived » BIRT » Concatenating strings in a dataset
Concatenating strings in a dataset [message #259077] Tue, 23 October 2007 07:20 Go to next message
Originally posted by: steve.eastman.ncmail.net
I would like to be able to concatenate strings in a dataset. Is there a
way to do this with Birt?
Re: Concatenating strings in a dataset [message #259095 is a reply to message #259077] Tue, 23 October 2007 11:10 Go to previous messageGo to next message
Steve,
You can add a computed column that combines existing columns using the
BIRT expression builder.
Jason
Re: Concatenating strings in a dataset [message #259271 is a reply to message #259095] Wed, 24 October 2007 08:36 Go to previous messageGo to next message
Thanks, Jason, but I guess I did not state my question clearly enough. I
have a column of strings and would like to combine them into a single long
string. It's similar to how BIRT allows you to Sum numbers in a column,
except this would be concatenating strings in the column. Any ideas on
this one?
Thanks--Steve
Re: Concatenating strings in a dataset [message #259300 is a reply to message #259271] Wed, 24 October 2007 11:24 Go to previous messageGo to next message
Steve,
Is this a one time operation, you could create a globalPersistentVariable
and just keep concatenating the strings into it. Kind of ugly but it should
work. If this is something that you want to use on a more consistent basis,
I would recommend extending the Aggregate Extension Point.
This extension point allows you to extend the Total... function. If your
function was named Total.sumString, then users would just invoke it through
the expression builder or the aggregate builder.
Scott Rosenbaum
> I have a column of strings and would like to combine them into a
> single long string. It's similar to how BIRT allows you to Sum
> numbers in a column, except this would be concatenating strings in the
> column. Any ideas on this one?
> Thanks--Steve
Re: Concatenating strings in a dataset [message #259440 is a reply to message #259300] Thu, 25 October 2007 07:48 Go to previous messageGo to next message
Thanks, Scott I will definitely pursue yur second approach.
Steve
Re: Concatenating strings in a dataset [message #259459 is a reply to message #259440] Thu, 25 October 2007 10:20 Go to previous message
Steve,
If you want an example, I have one for you out on my Subversion server.
Use the subclipse plug-in to login to
http://longlake.minnovent.com/repos/birt_example (anonymous read access)
Checkout the com.innoventsolutions.birt.aggregate project.
Scott Rosenbaum
> Thanks, Scott I will definitely pursue yur second approach. Steve
Previous Topic:Long string is truncated not wrapped
Next Topic:where is the console?
Current Time: Thu Oct 30 12:44:11 EDT 2025
Powered by FUDForum. Page generated in 0.04157 seconds
