Home » Eclipse Projects » Remote Application Platform (RAP) » Just another deploy problem in Tomcat
Just another deploy problem in Tomcat [message #25586] |
Thu, 17 May 2007 17:31  |
Hi all, I have a rare problem with tomcat.
First of all, I've followed deployment tutorial with rapdemo and It
works fine, but when I tryed to do the same with my app I found the next
problem:
Framework is launched.
id State Bundle
0 ACTIVE system.bundle_3.2.2.R32x_v20070118
1 INSTALLED com.autonomind.amvitae_1.0.0
2 ACTIVE org.eclipse.core.commands_3.2.0.I20060605-1400
3 ACTIVE org.eclipse.core.contenttype_3.2.0.v20060603
4 ACTIVE org.eclipse.core.jobs_3.2.0.v20060603
5 ACTIVE org.eclipse.core.runtime_3.2.0.v20060603
6 ACTIVE org.eclipse.equinox.common_3.2.0.v20060603
8 INSTALLED org.eclipse.equinox.http.registry_1.0.0.200705172204
9 INSTALLED org.eclipse.equinox.http.servlet_1.0.0.200705172204
10 INSTALLED
org.eclipse.equinox.http.servletbridge_1.0.0.200705172204
11 ACTIVE org.eclipse.equinox.preferences_3.2.1.R32x_v20060717
12 ACTIVE org.eclipse.equinox.registry_3.2.1.R32x_v20060814
13 ACTIVE org.eclipse.osgi.services_3.1.100.v20060601
14 INSTALLED org.eclipse.rap.jface_1.0.0.200705172204
15 INSTALLED org.eclipse.rap.rwt_1.0.0.200705172204
16 INSTALLED org.eclipse.rap.ui.workbench_1.0.0.200705172204
17 INSTALLED org.eclipse.rap.w4t_1.0.0.200705172204
18 INSTALLED org.eclipse.equinox.http.jetty_1.0.0.200705172204
Then I try to start manually and find this Exception:
osgi> start 17
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Import-Package: javax.servlet; version="2.3.0"
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:294)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.osgi.framework.internal.core.FrameworkCommandPro vider._start(FrameworkCommandProvider.java:239)
org.eclipse.osgi.framework.internal.core.FrameworkCommandInt erpreter.execute(FrameworkCommandInterpreter.java:145)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.do command(FrameworkConsole.java:293)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.co nsole(FrameworkConsole.java:278)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.ru n(FrameworkConsole.java:213)
at java.lang.Thread.run(Thread.java:613)
osgi>
I've read deployment tutorial and at first I haven't this line in my
MANIFEST.MF:
Import-Package: javax.servlet;version="[2.3.0,2.5.0)",
javax.servlet.http;version="[2.3.0,2.5.0)"
But now this line is included in MANIFEST.MF but the OSGi framework
doesn't work neither.
Any idea ?
Regards.
Roberto.
Re: Just another deploy problem in Tomcat [message #25627 is a reply to message #25586] |
Thu, 17 May 2007 19:09   |
OK, first problem solved :-) I had to delete "work" directory in tomcat.
New problem, all bundles are OK, but when I try to access to app an
exception is throwed:
osgi> java.lang.IllegalArgumentException: An entry point named 'default'
does not exist.
org.eclipse.swt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:70)
org.eclipse.swt.internal.lifecycle.PrepareUIRoot.execute(Pre pareUIRoot.java:32)
org.eclipse.swt.internal.lifecycle.RWTLifeCycle.execute(RWTL ifeCycle.java:60)
at com.w4t.engine.W4TModel$ServiceAdapter.execute(W4TModel.java :47)
com.w4t.engine.service.FormRequestServiceHandler.service(For mRequestServiceHandler.java:65)
Of course, It exists an Entrypoint called "default" in my app
"com.autonomind.amvitae_1.0.0", It works fine when a launch it from
eclipse directly.
I have this entry in plugin.xml:
<extension
id="com.autonomind.amvitae.entrypoint"
point="org.eclipse.rap.ui.workbench.entrypoint">
<entrypoint
class="com.autonomind.amvitae.EntryPoint"
parameter="default"/>
</extension>
And now all bundles seem to be OK:
osgi> ss
id State Bundle
Fragments=29
1 ACTIVE com.autonomind.amvitae_1.0.0
7 ACTIVE org.eclipse.equinox.http.registry_1.0.0.200705180025
8 ACTIVE org.eclipse.equinox.http.servlet_1.0.0.200705180025
9 ACTIVE
org.eclipse.equinox.http.servletbridge_1.0.0.200705180025
10 ACTIVE org.eclipse.equinox.preferences_3.2.1.R32x_v20060717
11 ACTIVE org.eclipse.equinox.registry_3.2.1.R32x_v20060814
12 ACTIVE org.eclipse.osgi.services_3.1.100.v20060601
13 ACTIVE org.eclipse.rap.jface_1.0.0.200705180025
14 ACTIVE org.eclipse.rap.rwt_1.0.0.200705180025
15 ACTIVE org.eclipse.rap.ui.workbench_1.0.0.200705180025
16 ACTIVE org.eclipse.rap.w4t_1.0.0.200705180025
17 ACTIVE org.eclipse.update.configurator_3.2.2.R32x_v20070111
29 RESOLVED org.eclipse.equinox.servletbridge.extensionbundle_1.0.0
Master=0
I have the feeling that I'm forgotting something, but I'm not be able to
see it, I suppose that It's too late ;-) , I hope to see it tomorrow,
but If someone has any idea...
Regards.
Roberto.
> problem:
> id State Bundle
> 10 INSTALLED org.eclipse.equinox.http.servletbridge_1.0.0.200705172204
> osgi> start 17
> at
> at
> at
> at
> at
> at
> at
> at
> at
> osgi>
> MANIFEST.MF:
> Any idea ?
> Regards.
> Roberto.
Re: Just another deploy problem in Tomcat [message #25664 is a reply to message #25627] |
Thu, 17 May 2007 19:20   |
Originally posted by: jkrause.innoopract.com
Please check the build.properties of your plugin project - are you
including plugin.xml in your build?
> does not exist.
> at
> at
> at
> at
> eclipse directly.
> <extension
> <entrypoint
> </extension>
> osgi> ss
> id State Bundle
> Fragments=29
> 9 ACTIVE org.eclipse.equinox.http.servletbridge_1.0.0.200705180025
> Master=0
> Regards.
> Roberto.
>> next problem:
>> id State Bundle
>> 10 INSTALLED
>> osgi> start 17
>> version="2.3.0"
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> osgi>
>> MANIFEST.MF:
>> Any idea ?
>> Regards.
>> Roberto.
Re: Just another deploy problem in Tomcat [message #25828 is a reply to message #25664] |
Fri, 18 May 2007 04:57  |
Thank you Jochen, That was exactly the problem.
In a few days my app will be ready for real world (I hope :-) )
Regards.
Roberto.
>> 'default' does not exist.
>> at
>> at
>> at
>> at
>> at
>> eclipse directly.
>> <extension
>> <entrypoint
>> </extension>
>> osgi> ss
>> id State Bundle
>> Fragments=29
>> 29 RESOLVED
>> Master=0
>> to see it, I suppose that It's too late ;-) , I hope to see it
>> tomorrow, but If someone has any idea...
>> Regards.
>> Roberto.
>>> next problem:
>>> id State Bundle
>>> 10 INSTALLED
>>> osgi> start 17
>>> version="2.3.0"
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> osgi>
>>> MANIFEST.MF:
>>> Any idea ?
>>> Regards.
>>> Roberto.
Current Time: Tue Oct 14 13:37:51 EDT 2025
Powered by FUDForum. Page generated in 0.04577 seconds
