Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » ASTVisitor.visitGeneral
ASTVisitor.visitGeneral [message #25580] Thu, 12 June 2008 12:25 Go to next message
Might I suggest that your method visitGeneral have the following
implementation:
public boolean visitGeneral(ASTNode node) throws Exception {
node.traverse(this);
return true;
This should make sure that every node in the tree is traversed by default,
even if the visitor does nothing with each node.
Chuck
Re: ASTVisitor.visitGeneral [message #25619 is a reply to message #25580] Thu, 12 June 2008 16:53 Go to previous message
Please ignore this post.
I got confused.
It is now my understanding that ASTNode and its subclasses will implement
the traverse method
to
a) call visitor.visit(this)
b) call traverse(visitor) on any child nodes
c) call visitor.endvisit(this)
Each Visitor class simple operates on each node it is passed in visit and
endvisit.
Chuck
"Chuck Doucette" <cdoucette@vaultus.com> wrote in message
news:g2rint$sae$1@build.eclipse.org...
> implementation:
> return true;
> Chuck
Previous Topic:(org.eclipse.dltk.ui.text.completion.)ProposalInfo.getHTMLContentReader:150 - NullPointerException
Next Topic:type hierarchy and code completion
Current Time: Sat Oct 25 14:15:47 EDT 2025
Powered by FUDForum. Page generated in 0.03592 seconds
