Re: [buckminster-dev] PDE headless build of RCP headless product ... "The System Bundle's start [message #25579] |
Fri, 19 September 2008 13:19 |
Hi Ki,
Would it be possible for me to view the two config.ini files? I.e. the
one generated by PDE and the one generated by Buckminster?
- thomas
Ki Alam wrote:
> Thanks, Thomas,
> We did not use a custom config.ini, but looking into it, it turned out
> that the config.ini from our original PDE-headless-build system
> generated correctly using the configurator bundle, but the buckminster
> generated config.ini just wouldn't work.
> Is there some reason that the PDE build and buckminster don't generate
> identical config.ini files?
> This is buckminster for 3.4.
> Again, many thanks.
> Ki
> Date: Fri, 19 Sep 2008 07:53:33 +0200
> From: Thomas Hallgren <thomas@tada.se <mailto:thomas@tada.se>>
> Subject: Re: [buckminster-dev] PDE headless build of RCP headless
> product ... "The System Bundle's start level can not be
> modified."
> To: Buckminster developer discussions <buckminster-dev@eclipse.org
> <mailto:buckminster-dev@eclipse.org>>
> Message-ID: <48D33E5D.8050206@tada.se <mailto:48D33E5D.8050206@tada.se>>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Hi Ki,
> Do you have a custom config.ini file for you RCP app?
> Are you using Buckminster for 3.3 or 3.4?
> Thomas Hallgren
> Ki Alam wrote:
> > Hi there.
> > We are trying to transition our build from the PDE headless build to
> > the buckminster headless build. We got through the resolve bits and
> > are able to build , but when trying to run the build, we get the
> > following error:
> > !SESSION 2008-09-18 05:18:19.011
> > eclipse.buildId=unknown
> > java.version=1.6.0_03
> > java.vendor=Sun Microsystems Inc.
> > BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
> > !ENTRY org.eclipse.osgi 4 0 2008-09-18 05:18:19.654
> > !MESSAGE An unexpected runtime error has occurred.
> > !STACK 0
> > java.lang.IllegalArgumentException: The System Bundle's start level
> > can not be modified.
> > at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.s etBundleStartLevel(StartLevelManager.java:415)
> > at
> org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:1117)
> > at
> org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:642)
> > at
> org.eclipse.core.runtime.adaptor.EclipseStarter.access$1(Ecl ipseStarter.java:619)
> > at
> org.eclipse.core.runtime.adaptor.EclipseStarter$1.bundleChan ged(EclipseStarter.java:308)
> > at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1234)
> > at
> org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
> > at
> org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
> > at
> org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEventPrivileged(Framework.java:1518)
> > at
> org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEvent(Framework.java:1469)
> > at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:281)
> > at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:247)
> > at
> org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:201)
> > at
> org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:644)
> > at
> > org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
> > at
> org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:313)
> > at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> > at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> > at java.lang.reflect.Method.invoke(Method.java:597) at
> > org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> > at
> > org.eclipse.equinox.launcher.Main.basicRun(Main.java:504) at
> > org.eclipse.equinox.launcher.Main.run(Main.java:1236)
> > at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
> > !ENTRY org.eclipse.osgi 4 0 2008-09-18 05:18:19.655
> > !MESSAGE
> > !STACK 0
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > !ENTRY org.eclipse.osgi 4 0 2008-09-18 05:18:19.656
> > !MESSAGE Application error
> > !STACK 1
> > java.lang.IllegalStateException: Platform not running
> > at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:370)
> > at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> > Followed by the bundles not being able to be resolved:
> > !ENTRY org.eclipse.osgi 2 0 2008-09-18 05:18:19.677
> > !MESSAGE One or more bundles are not resolved because the following
> > root constraints are not resolved:
> > !SUBENTRY 1 org.eclipse.osgi 2 0 2008-09-18 05:18:19.677
> > !MESSAGE Bundle
> > initial@reference:file:plugins/m365.agent.logmessageservice_1.0.0.jar/
> > was not resolved.
> > !SUBENTRY 2 m365.agent.logmessageservice 2 0 2008-09-18 05:18:19.678
> > !MESSAGE Missing required bundle wily.introscope.em_0.0.0.
> > !SUBENTRY 1 org.eclipse.osgi 2 0 2008-09-18 05:18:19.678
> > !MESSAGE Bundle
> initial@reference :file:plugins/m365.embeddedem.datacenter.properties_1.0.0.ja r/
> > was not resolved.
> > !SUBENTRY 2 m365.embeddedem.datacenter.properties 2 0 2008-09-18
> > 05:18:19.678
> > !MESSAGE Missing host wily.introscope.em_1.0.0.
> > !MESSAGE Bundle
> initial@reference:file:plugins/m365.messaging.transport.sender_1.0.0.jar/
> > was not resolved.
> > !SUBENTRY 2 m365.messaging.transport.sender 2 0 2008-09-18 05:18:19.678
> > !MESSAGE Missing imported package m365_0.0.0.
> > !MESSAGE Bundle
> initial@reference:file:plugins/m365.agent.classanalysis.isengard_1.0.0.jar/
> > was not resolved.
> > !SUBENTRY 2 m365.agent.classanalysis.isengard 2 0 2008-09-18
> 05:18:19.678
> > !MESSAGE Bundle
> > initial@reference:file:plugins/m365.isengard_1.0.0.jar/ was not
> resolved.
> > !SUBENTRY 2 m365.isengard 2 0 2008-09-18 05:18:19.678
> > We are able to build using the existing PDE-headless build ... has
> > anyone run into this?
> > Thanks,
> > Ki
> > _______________________________________________
> > buckminster-dev mailing list
> > buckminster-dev@eclipse.org <mailto:buckminster-dev@eclipse.org>
> > https://dev.eclipse.org/mailman/listinfo/buckminster-dev
FUDForum. Page generated in 0.02346 seconds
