Home » Newcomers » Newcomers » License problem in installing a plug-in using update site
License problem in installing a plug-in using update site [message #258751] Wed, 18 June 2008 09:24 Go to next message
Originally posted by: kabel133.gmail.com
Hello everybody,
I created an editor as a plug-in, but sometimes I'm not able to install
it. I created Feature Project with my plug-in and after that I created
Update Site Project. I added the feature and built it. Everything was ok,
I was able to install my plug-in using update site. After some time (about
1 month) I tried to install it again (the plug-in was uninstalled), but
there was a problem with "... feature does not have a valid license
agreement". I just rebuilt the update site without any change and after
doing this I was able to install it again. Now, I met with this problem
again. Does anybody know why?
So, I rebuilt the update site. My friends also tried to install it and it
works, but one of them has a problem with: "Resulting configuration does
not contain the platform". He is also not able to install it using direct
installation (copy a JAR archive of my plug-in into eclipse/plugins) :(
Thanks for help
Re: License problem in installing a plug-in using update site [message #258756 is a reply to message #258751] Wed, 18 June 2008 14:06 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
What version of Eclipse are you using / targeting?
Andy wrote:
> Hello everybody,
> ok, I was able to install my plug-in using update site. After some time
> (about 1 month) I tried to install it again (the plug-in was
> uninstalled), but there was a problem with "... feature does not have a
> valid license agreement". I just rebuilt the update site without any
> change and after doing this I was able to install it again. Now, I met
> with this problem again. Does anybody know why?
> it works, but one of them has a problem with: "Resulting configuration
> does not contain the platform". He is also not able to install it using
> direct installation (copy a JAR archive of my plug-in into
> eclipse/plugins) :(
> Thanks for help
Re: License problem in installing a plug-in using update site [message #258772 is a reply to message #258756] Wed, 18 June 2008 17:22 Go to previous messageGo to next message
I tested it on Eclipse 3.3.1.1 and 3.3.2
Re: License problem in installing a plug-in using update site [message #258780 is a reply to message #258772] Wed, 18 June 2008 18:59 Go to previous messageGo to next message
Any chance you want to try Eclipse 3.4? 3.4's p2 Install Manager is much
more robust than Eclipse 3.3's Update Manager. And 3.4 releases in 7 days...
N
> Andy wrote:
>> Hello everybody,
>> I created an editor as a plug-in, but sometimes I'm not able to install it. I created Feature Project with my plug-in and after that I created Update Site Project. I added the feature and built it. Everything was ok, I was able to install my plug-in using update site. After some time (about 1 month) I tried to install it again (the plug-in was uninstalled), but there was a problem with "... feature does not have a valid license agreement". I just rebuilt the update site without any change and after doing this I was able to install it again. Now, I met with this problem again. Does anybody know why?
>> So, I rebuilt the update site. My friends also tried to install it and it works, but one of them has a problem with: "Resulting configuration does not contain the platform". He is also not able to install it using direct installation (copy a JAR archive of my plug-in into eclipse/plugins) :(
>> Thanks for help
Re: License problem in installing a plug-in using update site [message #258801 is a reply to message #258780] Thu, 19 June 2008 09:33 Go to previous message
This doesn't solve my problem :(
BTW is this Eclipse behavior normally? Or am I doing something wrong?
Previous Topic:E startup problems
Next Topic:Making Custom Dialog Boxes
Current Time: Wed Jan 15 07:16:18 GMT 2025
Powered by FUDForum. Page generated in 0.07598 seconds
