Error on plug-in installation with eclipse 3.0 [message #258332] |
Mon, 05 July 2004 08:56 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: richard.grossman.mobilitec.com
I got some plug-in like VSS plugin 1.6.0 version is OK for eclipse 3.0
final.
when I try to install it I got :
!SESSION Mon Jul 05 08:15:03 GMT
2004 ------------------------------------------
!ENTRY org.eclipse.core.launcher 4 0 Jul 05, 2004 08:15:03.734
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.RuntimeException: Could not find framework
at org.eclipse.core.launcher.Main.getBootPath(Main.java:355)
at org.eclipse.core.launcher.Main.basicRun(Main.java:172)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
The same error occurs on other plug-in,
Help please
Richard Grossman
Re: Error on plug-in installation with eclipse 3.0 [message #258383 is a reply to message #258332] |
Mon, 05 July 2004 11:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: pascal.ibm.canada
It looks like you overwrote some files in the org.eclipse.osgi plugin.
PaScaL
Richard Grossman wrote:
> final.
> !STACK
> Help please
> Richard Grossman
Re: Error on plug-in installation with eclipse 3.0 [message #258670 is a reply to message #258383] |
Tue, 06 July 2004 10:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Not at all,
Nothing has been touched in this plug-in dir
Something else ?
Richard
"Pascal Rapicault" <pascal@ibm.canada> wrote in message
news:ccbfe9$fnr$1@eclipse.org...
> PaScaL
> > Hi,
> > final.
> > !STACK
> > Help please
> > Richard Grossman
Re: Error on plug-in installation with eclipse 3.0 [message #258700 is a reply to message #258670] |
Tue, 06 July 2004 11:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Are you sure that the zip you dl was not corrupted?
Can you verify that the vss archive that you get does not explodes files
in other folders than where it is supposed to?
If it is reproduceable please enter a bug report in equinox / general.
PaScaL
> Not at all,
> Something else ?
> Richard
>>PaScaL
>>>Hi,
>>>final.
>>>!STACK
>>>Help please
>>>Richard Grossman
Re: Error on plug-in installation with eclipse 3.0 [message #259007 is a reply to message #258700] |
Wed, 07 July 2004 07:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
After some test, I've take the source of the plug in I've recompile all and
rebuild the plug-in when i try it by launching via the plug-in editor of
eclipse the runtine workbench load the plug in without problem. When I take
the Zip file produced and unzip it into the real eclipse plug-in dir I got
this error.
What do you think ?
Richard
news:cce2ua$p8d$1@eclipse.org...
> PaScaL
> > Not at all,
> > Something else ?
> > Richard
> >>PaScaL
> >>>Hi,
> >>>final.
> >>>!STACK
> >>>Help please
> >>>Richard Grossman
FUDForum. Page generated in 0.03915 seconds
