Re: junit and external file [message #258083 is a reply to message #258014] |
Wed, 11 June 2008 04:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
No real name![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=elekis%40gmail.com) Messages: 64 Registered: July 2009 |
Member |
Wayne Beaton a écrit :
> YOur first and best choice is to include the file in the JAR and use the
> Class.getResourceAsStream() method to get it. This, however, doesn't
> work so well if you have to write to the file. It does have the benefit
> of working anywhere, including a JAR or bundle.
> Another option is to explicitly set the working directory in your launch
> configuration (on the Arguments tab).
> HTH,
> Wayne
> On Tue, 2008-06-10 at 17:25 +0200, julien wrote:
>> hi all
>> I have to make junit test with external file in simple
>> I have to open a file , read some data , (see if there are correct) etc..;
>> le prob is how to have the same path even if test move to another pc.
>> my best solution is put that on the jar itself but what is the reltive
>> path of the current jar??
>> thanks
>> a++
thanks,
I ll look
a++
FUDForum. Page generated in 0.10003 seconds
