Home » Language IDEs » Java Development Tools (JDT) » JDT Builder : My .emtl files in the Java output folder
JDT Builder : My .emtl files in the Java output folder [message #257753] Thu, 11 December 2008 13:33 Go to next message
I'm writing the M2T/MTL builder
I have an .mtl file in a java source folder (src) and I create an .emtl
file in the output source folder (bin)
It works but sometimes my .emtl files are deleted in the "bin" folder
(I don't have to wait more than 2 minutes)
I have disabled the JDT build, and now it works
I think that the JDT builder deletes bad files (old output files)
But for MTL, the .emtl file is like the .class file
How can I do?
Is there an extension point to keep that kind of files in the output folder?
Jonathan Musset
Re: JDT Builder : My .emtl files in the Java output folder [message #257770 is a reply to message #257753] Thu, 11 December 2008 20:22 Go to previous messageGo to next message
Jonathan MUSSET wrote:
> How can I do?
> folder?
Can you output your .emtl files to a different folder than "bin", and
then just add that folder to the build.properties or whatever you are
using to produce your final artifact?
Re: JDT Builder : My .emtl files in the Java output folder [message #257781 is a reply to message #257770] Fri, 12 December 2008 08:30 Go to previous messageGo to next message
Thank you Walter,
The problem is that I would like to build my .emtl files with my .class
files, in the same jar
I need to have my .emtl files in the java classpath
A solution is to rename .emtl to .mtl
It works if I have the same name both in the 'src' folder and in the
'bin' folder.
But, why the .class files are not automatically deleted by the Java
builder? "Sample.java" != "Sample.class"
I would like to do the same kind of thing.
My builder is able to delete my old .emtl files
Why the Java builder do that for me? Is it a bug? Is there a workaround?
Jonathan
>> .emtl file in the output source folder (bin)
>> How can I do?
>> folder?
Re: JDT Builder : My .emtl files in the Java output folder [message #257829 is a reply to message #257781] Tue, 16 December 2008 11:21 Go to previous message
Has anyone an answer to these questions?
Jonathan MUSSET a écrit :
> Thank you Walter,
> 'bin' folder.
> Cheers,
> Jonathan
>>> Hi,
>>> How can I do?
>>> folder?
Previous Topic:jump to resource in navigator
Next Topic:Problem with JUnit 4 / JUNIT_HOME
Current Time: Thu Nov 06 18:23:32 EST 2025
Powered by FUDForum. Page generated in 0.05051 seconds
