page encoding [message #257036] |
Wed, 30 June 2004 06:15  |
Originally posted by: bbozek.email.hinet.hr
How I can write Croatian characters to database.
I am using MS SQL 2000 with window Croatian collation,
and "<%@ page contentType="text/html; charset=ISO-8859-2"%>" directive on
jsp page.
Reading Croatian characters from database to jsp page work fine,
but when writing characters like "c,s,d" field in database is populated with
"e, ?....".
Branko
Re: page encoding [message #257142 is a reply to message #257036] |
Wed, 30 June 2004 12:07  |
You're basically asking about behavior of running program, right? Not how
the Eclipse tools are handling your files?
If so, a good link I've seen on this recently is
http://www.javaworld.com/javaworld/jw-04-2004/jw-0419-multib ytes_p.html
If its a tools issue, and I assume you're using Eclipse 3.0, then there
may be charset properties on the file you'll have to set. The base Eclipse
does not know what to do with page directives.
> jsp page.
> with
> "e, ?....".
> Thanks
> Branko
FUDForum. Page generated in 0.02742 seconds
