Home » Archived » BIRT » Change theme by script
Change theme by script [message #256961] |
Wed, 03 October 2007 19:52 |
Originally posted by: raison.fermat.eu
With BIRT 2.1.1, we used in all our reports a parameter which list
available themes in library. It's easy then to change the running theme
using initialize script of the report (if someone want an example,
there's no problem).
But, since the 2.2.0 there is a strange behaviour of the web viewer
(using frameset). When loading the report, the user choice for the theme
works but when asking the change parameter again, it doesn't work (the
theme can not be found even with theme=(ThemeHandle)x or with
setThemeName() method).
I saw in eclipse bugzilla a lot of bugs according to script method in
the 2.2.0. So I also log this one into bugzilla since more than a week
and nobody answers (https://bugs.eclipse.org/bugs/show_bug.cgi?id=204597).
The 2.2.1 it released, it doesn't work in the last nightly i tested and
nobody cares ...
Is there someone looking to Web Viewer bugs ???
Thibaud
Re: Change theme by script [message #257053 is a reply to message #256961] |
Thu, 04 October 2007 14:46 |
Thibaud,
I am not certain why this happening. Do this happen when using the
deployed viewer? I believe it may have something to do with the
rptdocument not being recreated (not positive). If you make this change
in the BirtParameterDialog.js I believe it will work.
else if ( true )//this.__ifSubmit( this.__mode, action ) )
This will make it refresh the whole browser url.
Jason
Thibaud wrote:
> Hello,
> nobody cares ...
> Thibaud
Re: Change theme by script [message #257123 is a reply to message #257053] |
Thu, 04 October 2007 19:17 |
Thanks a lot Jason,
I will try this solution and check if the rptdocument is rewrited.
I post in the bugzilla entry that it's the same in 2.2.1 also.
I use the view report in Web viewer shortcut.
In the preview it works well.
Thibaud
Jason Weathersby a écrit :
> Thibaud,
> Jason
> Thibaud wrote:
>> Hello,
>> theme using initialize script of the report (if someone want an
>> example, there's no problem).
>> theme works but when asking the change parameter again, it doesn't
>> work (the theme can not be found even with theme=(ThemeHandle)x or
>> with setThemeName() method).
>> and nobody answers
>> and nobody cares ...
>> Thibaud
Re: Change theme by script [message #257179 is a reply to message #257053] |
Thu, 04 October 2007 20:14 |
Can the report change, without a new rptdocument ?
In my example, I display the parameter value for the theme name.
The value is OK, so I thought a new rptdocument has been rewrited ?
Am I right ?
> Thibaud,
> Jason
> Thibaud wrote:
>> Hello,
>> and nobody answers
>> Thibaud
Re: Change theme by script [message #257196 is a reply to message #257179] |
Thu, 04 October 2007 21:01 |
According to the timestamp of the file, the rptdocument is rewrited.
The forced submit doesn't change anything.
I also checked with firebug that the _doSubmit is done.
The only thing which works, is before changing the parameter value, to
delete the rptdocument. Then it works and the theme changes ... of course.
> Am I right ?
>> Thibaud,
>> change in the BirtParameterDialog.js I believe it will work.
>> Jason
>> Thibaud wrote:
>>> Hello,
>>> week and nobody answers
>>> Thibaud
Re: Change theme by script [message #257204 is a reply to message #257196] |
Thu, 04 October 2007 22:12 |
Thibaud,
It has to overwrite the document. This worked on mine. In that same
file you can also append &__overwrite=true to the action. BTW my
default overwrite is set to true in the web.xml.
Jason
>> Am I right ?
>>> Thibaud,
>>> Jason
>>> Thibaud wrote:
>>>> Hello,
>>>> in the 2.2.0. So I also log this one into bugzilla since more than a
>>>> Thibaud
Re: Change theme by script [message #257357 is a reply to message #257204] |
Fri, 05 October 2007 20:37 |
OK Jason, it works.
Modify the BirtParameterDialog.js and set to true the overwrite
parameter works. Thanks a lot for your help.
Is it really the way it has to work ?
I still consider this behaviour as a bug.
One day i have to ask how the cache works ;)
I will post this solution in the bug, if one day someone read it !!!
Thanks again,
> Thibaud,
> Jason
>> course.
>>> Am I right ?
>>>> Thibaud,
>>>> Jason
>>>> Thibaud wrote:
>>>>> Hello,
>>>>> a week and nobody answers
>>>>> Thibaud
Current Time: Sat Jul 27 16:31:06 GMT 2024
Powered by FUDForum. Page generated in 0.04228 seconds
