Home » Archived » BIRT » BIRT 2.2.1 Web Viewer report as PDF problem?
BIRT 2.2.1 Web Viewer report as PDF problem? [message #256944] Wed, 03 October 2007 18:10
Rob Scott is currently offline Rob ScottFriend
I have just upgraded to version BIRT 2.2.1.
The report designer seems to work OK whether the output is HTML, HTML+Ajax
or PDF.
However, using the report viewer, HTML and HTML+Ajax are OK, but PDF does
not output. It looks like the report is being run on the server, but
Acrobat Reader does not start up embedded and show the report like it used
to do in all other versions of the Runtime that I have tried.
Anyone else have this problem?
I am on Linux and Firefox with the Adobe Acrobat reader installed.
Previous Topic:Modify Chart Grouping Settings at Runtime?
Next Topic:Dynamic x-axis markers & hyperlinks
Current Time: Thu Aug 29 12:36:42 GMT 2024
Powered by FUDForum. Page generated in 0.03909 seconds
