Home » Archived » BIRT » Running a design local
Running a design local [message #256862] Wed, 03 October 2007 09:57 Go to next message
Originally posted by: westland.nachon.nl
I want to call a design with an url. Everything works fine, but when I
disconnect from my network, I got a message in IE saying that the page
is unavailable. Reconnect to the netwerk, refresh, and it works again.
Does anyone have a clue?
Grz,
Rob
Re: Running a design local [message #256981 is a reply to message #256862] Thu, 04 October 2007 00:01 Go to previous messageGo to next message
Rob,
What url are you using? If you disconnect and restart eclipse do you
have the same issue?
Jason
Rob Westland wrote:
> Grz,
> Rob
Re: Running a design local [message #257286 is a reply to message #256981] Fri, 05 October 2007 07:28 Go to previous messageGo to next message
This is the url:
http://localhost:8080/birt-viewer/run?__report=Test999/Ritov erzicht.rptdesign&__format=pdf
I did not (yet) exactly disconnect and restart, but I disconnected while
jboss is running.
Rob
Jason Weathersby schreef:
> Rob,
> Jason
> Rob Westland wrote:
>> Grz,
>> Rob
Re: Running a design local [message #257489 is a reply to message #257286] Mon, 08 October 2007 14:37 Go to previous message
Rob,
I just wander is something is going on with your IP that may cause a
problem.
Jason
Rob Westland wrote:
> This is the url:
> jboss is running.
> Rob
>> Rob,
>> Jason
>> Rob Westland wrote:
>>> Hi,
>>> I disconnect from my network, I got a message in IE saying that the
>>> page is unavailable. Reconnect to the netwerk, refresh, and it works
>>> again.
>>> Grz,
>>> Rob
Previous Topic:How to keep data for a row on same page
Next Topic:How i integrate charts and tables from BIRT-Reports to a library?
Current Time: Thu Dec 26 11:15:45 GMT 2024
Powered by FUDForum. Page generated in 0.02967 seconds
