Home » Eclipse Projects » Eclipse Platform » Eclipse 3.0 core dumping on Mandrake 10.0
Eclipse 3.0 core dumping on Mandrake 10.0 [message #256722] Tue, 29 June 2004 13:23
Envionment
Eclipse 3.0
Mandrake 10.0
kernel 2.6.3
NVIDIA 5336 driver
Pentium4 1.8GHZ
1GB ram
JVM 1.4.2_04
---------------------------Start of hs_err_XXX.log --------------
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x4D88853C
Function=XftCharIndex+0x1C
Library=/usr/X11R6/lib/libXft.so.2
Current Java thread:
at org.eclipse.swt.internal.motif.OS.XtDispatchEvent(Native Method)
- locked <0x48b0fa30> (a java.lang.Class)
at org.eclipse.swt.widgets.Display.update(Display.java:3429)
at org.eclipse.swt.widgets.Shell.setVisible(Shell.java:1384)
at org.eclipse.swt.widgets.Shell.open(Shell.java:1023)
at org.eclipse.jface.window.Window.open(Window.java:644)
org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.prompt(Cho oseWorkspaceDialog.java:65)
org.eclipse.ui.internal.ide.IDEApplication.promptForWorkspac e(IDEApplication.java:314)
org.eclipse.ui.internal.ide.IDEApplication.checkInstanceLoca tion(IDEApplication.java:219)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:83)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Dynamic libraries:
08048000-0804e000 r-xp 00000000 03:02 2492068
/usr/java/j2sdk1.4.2_04/bin/java
0804e000-0804f000 rw-p 00005000 03:02 2492068
40000000-40016000 r-xp 00000000 03:01 2534575 /lib/ld-2.3.3.so
40016000-40017000 rw-p 00015000 03:01 2534575 /lib/ld-2.3.3.so
4002c000-40039000 r-xp 00000000 03:01 2534619 /lib/tls/libpthread-0.10.so
40039000-4003a000 rw-p 0000d000 03:01 2534619 /lib/tls/libpthread-0.10.so
4003c000-4003e000 r-xp 00000000 03:01 2534586 /lib/libdl-2.3.3.so
4003e000-4003f000 rw-p 00001000 03:01 2534586 /lib/libdl-2.3.3.so
4003f000-40181000 r-xp 00000000 03:01 2534615 /lib/tls/libc-2.3.3.so
40181000-40184000 rw-p 00142000 03:01 2534615 /lib/tls/libc-2.3.3.so
40188000-40583000 r-xp 00000000 03:02 2475803
/usr/java/j2sdk1.4.2_04/jre/lib/i386/client/libjvm.so
40583000-4059e000 rw-p 003fa000 03:02 2475803
405b1000-405b9000 r-xp 00000000 03:02 2475797
/usr/java/j2sdk1.4.2_04/jre/lib/i386/native_threads/libhpi.s o
405b9000-405ba000 rw-p 00007000 03:02 2475797
405c4000-405d4000 r-xp 00000000 03:01 2534590 /lib/libnsl-2.3.3.so
405d4000-405d5000 rw-p 00010000 03:01 2534590 /lib/libnsl-2.3.3.so
405d7000-405f9000 r-xp 00000000 03:01 2534617 /lib/tls/libm-2.3.3.so
405f9000-405fa000 rw-p 00021000 03:01 2534617 /lib/tls/libm-2.3.3.so
405fa000-405fe000 rw-s 00000000 03:01 2174826 /tmp/hsperfdata_root/2962
4060d000-40617000 r-xp 00000000 03:01 2534596 /lib/libnss_files-2.3.3.so
40617000-40618000 rw-p 00009000 03:01 2534596 /lib/libnss_files-2.3.3.so
40618000-40628000 r-xp 00000000 03:02 2475808
/usr/java/j2sdk1.4.2_04/jre/lib/i386/libverify.so
40628000-4062a000 rw-p 0000f000 03:02 2475808
4062a000-4064a000 r-xp 00000000 03:02 2475809
/usr/java/j2sdk1.4.2_04/jre/lib/i386/libjava.so
4064a000-4064c000 rw-p 0001f000 03:02 2475809
4064c000-40660000 r-xp 00000000 03:02 2475811
/usr/java/j2sdk1.4.2_04/jre/lib/i386/libzip.so
40660000-40663000 rw-p 00013000 03:02 2475811
40663000-42003000 r--s 00000000 03:02 2476420
/usr/java/j2sdk1.4.2_04/jre/lib/rt.jar
4204d000-42063000 r--s 00000000 03:02 2475838
/usr/java/j2sdk1.4.2_04/jre/lib/sunrsasign.jar
42063000-4213e000 r--s 00000000 03:02 2476328
/usr/java/j2sdk1.4.2_04/jre/lib/jsse.jar
4213e000-4214f000 r--s 00000000 03:02 2475839
/usr/java/j2sdk1.4.2_04/jre/lib/jce.jar
4214f000-426a8000 r--s 00000000 03:02 2476366
/usr/java/j2sdk1.4.2_04/jre/lib/charsets.jar
4c953000-4c97f000 r--p 00000000 03:02 1938623
/usr/share/locale/ISO-8859-1/LC_CTYPE
4cb83000-4cb9f000 r--s 00000000 03:02 2475834
/usr/java/j2sdk1.4.2_04/jre/lib/ext/sunjce_provider.jar
4cb9f000-4cba2000 r--s 00000000 03:02 2475835
/usr/java/j2sdk1.4.2_04/jre/lib/ext/dnsns.jar
4cba2000-4cbaf000 r--s 00000000 03:02 2475837
/usr/java/j2sdk1.4.2_04/jre/lib/ext/ldapsec.jar
4cbaf000-4cc6b000 r--s 00000000 03:02 2476367
/usr/java/j2sdk1.4.2_04/jre/lib/ext/localedata.jar
4cc6b000-4cc70000 r--s 00000000 03:01 34259 /opt/eclipse/startup.jar
4ccf1000-4cd29000 r--s 00000000 03:01 32720
/opt/eclipse/plugins/org.eclipse.osgi_3.0.0/core.jar
4cd29000-4cd31000 r--s 00000000 03:01 32721
/opt/eclipse/plugins/org.eclipse.osgi_3.0.0/console.jar
4cd31000-4cd3d000 r--s 00000000 03:01 32719
/opt/eclipse/plugins/org.eclipse.osgi_3.0.0/osgi.jar
4cd3d000-4cd53000 r--s 00000000 03:01 32723
/opt/eclipse/plugins/org.eclipse.osgi_3.0.0/resolver.jar
4cd53000-4cd69000 r--s 00000000 03:01 32724
/opt/eclipse/plugins/org.eclipse.osgi_3.0.0/defaultAdaptor.j ar
4cd69000-4cd88000 r--s 00000000 03:01 32722
/opt/eclipse/plugins/org.eclipse.osgi_3.0.0/eclipseAdaptor.j ar
4ce8a000-4ce9a000 r-xp 00000000 03:02 2475814
/usr/java/j2sdk1.4.2_04/jre/lib/i386/libnet.so
4ce9a000-4ce9b000 rw-p 0000f000 03:02 2475814
4ce9b000-4ce9c000 r--s 00000000 03:01 65812
/opt/eclipse/plugins/org.eclipse.swt.motif_3.0.0/ws/motif/sw t-gtk.jar
4cf1f000-4cf76000 r--s 00000000 03:01 32882
/opt/eclipse/plugins/org.eclipse.core.runtime_3.0.0/runtime. jar
4cf76000-4cf7c000 r-xp 00000000 03:02 2475815
/usr/java/j2sdk1.4.2_04/jre/lib/i386/libnio.so
4cf7c000-4cf7d000 rw-p 00005000 03:02 2475815
4cf7d000-4cf91000 r--s 00000000 03:01 65838
/opt/eclipse/plugins/org.eclipse.update.configurator_3.0.0/c onfigurator.jar
4cf91000-4d0df000 r--s 00000000 03:01 33853
/opt/eclipse/plugins/org.eclipse.ui.ide_3.0.0/ide.jar
4d0df000-4d0f4000 r--s 00000000 03:01 33409
/opt/eclipse/plugins/org.eclipse.core.runtime.compatibility_ 3.0.0/compatibility.jar
4d0f4000-4d0f5000 r--s 00000000 03:01 65834
/opt/eclipse/plugins/org.eclipse.ui.workbench.compatibility_ 3.0.0/compatibility.jar
4d0f5000-4d328000 r--s 00000000 03:01 33404
/opt/eclipse/plugins/org.eclipse.ui.workbench_3.0.0/workbenc h.jar
4d328000-4d3a6000 r--s 00000000 03:01 34239
/opt/eclipse/plugins/org.eclipse.jface_3.0.0/jface.jar
4d3a6000-4d3b9000 r--s 00000000 03:01 65813
/opt/eclipse/plugins/org.eclipse.swt.motif_3.0.0/ws/motif/sw t-mozilla.jar
4d3b9000-4d4b6000 r--s 00000000 03:01 65814
/opt/eclipse/plugins/org.eclipse.swt.motif_3.0.0/ws/motif/sw t.jar
4d4b6000-4d4b7000 r--s 00000000 03:01 49901
/opt/eclipse/plugins/org.eclipse.ui_3.0.0/ui.jar
4d4b7000-4d4fd000 r-xp 00000000 03:01 65822
/opt/eclipse/plugins/org.eclipse.swt.motif_3.0.0/os/linux/x8 6/libswt-motif-3062.so
4d4fd000-4d500000 rw-p 00046000 03:01 65822
4d500000-4d502000 r-xp 00000000 03:02 1205327
/usr/X11R6/lib/X11/locale/lib/common/xlcDef.so.2
4d502000-4d503000 rw-p 00001000 03:02 1205327
4d503000-4d504000 r--p 00000000 03:02 1938980
/usr/share/locale/en_US/LC_IDENTIFICATION
4d504000-4d505000 r--p 00000000 03:02 1938979
/usr/share/locale/en_US/LC_MEASUREMENT
4d505000-4d506000 r--p 00000000 03:02 1938973
/usr/share/locale/en_US/LC_TELEPHONE
4d506000-4d507000 r--p 00000000 03:02 1938981
/usr/share/locale/en_US/LC_ADDRESS
4d507000-4d508000 r--p 00000000 03:02 1938976
/usr/share/locale/en_US/LC_NAME
4d508000-4d509000 r--p 00000000 03:02 1938974
/usr/share/locale/en_US/LC_PAPER
4d509000-4d50a000 r--p 00000000 03:02 1938978
/usr/share/locale/en_US/LC_MESSAGES/SYS_LC_MESSAGES
4d50a000-4d50b000 r--p 00000000 03:02 1938977
/usr/share/locale/en_US/LC_MONETARY
4d50b000-4d511000 r--p 00000000 03:02 1938624
/usr/share/locale/ISO-8859-1/LC_COLLATE
4d511000-4d512000 r--p 00000000 03:02 1938972
/usr/share/locale/en_US/LC_TIME
4d512000-4d513000 r--p 00000000 03:02 1938975
/usr/share/locale/en_US/LC_NUMERIC
4d513000-4d687000 r-xp 00000000 03:02 1208728
/usr/X11R6/lib/libXm.so.2.0.1
4d687000-4d698000 rw-p 00174000 03:02 1208728
4d69b000-4d77a000 r-xp 00000000 03:02 1205343
/usr/X11R6/lib/libX11.so.6.2
4d77a000-4d77d000 rw-p 000de000 03:02 1205343
4d77d000-4d78a000 r-xp 00000000 03:02 1205353
/usr/X11R6/lib/libXext.so.6.4
4d78a000-4d78b000 rw-p 0000d000 03:02 1205353
4d78b000-4d7db000 r-xp 00000000 03:02 1205377 /usr/X11R6/lib/libXt.so.6.0
4d7db000-4d7df000 rw-p 0004f000 03:02 1205377 /usr/X11R6/lib/libXt.so.6.0
4d7df000-4d7e6000 r-xp 00000000 03:02 1205369 /usr/X11R6/lib/libXp.so.6.2
4d7e6000-4d7e7000 rw-p 00006000 03:02 1205369 /usr/X11R6/lib/libXp.so.6.2
4d7e7000-4d7ec000 r-xp 00000000 03:02 1205379
/usr/X11R6/lib/libXtst.so.6.1
4d7ec000-4d7ed000 rw-p 00004000 03:02 1205379
4d7ed000-4d7f5000 r-xp 00000000 03:02 1205341 /usr/X11R6/lib/libSM.so.6.0
4d7f5000-4d7f6000 rw-p 00007000 03:02 1205341 /usr/X11R6/lib/libSM.so.6.0
4d7f6000-4d80a000 r-xp 00000000 03:02 1205337
/usr/X11R6/lib/libICE.so.6.3
4d80a000-4d80c000 rw-p 00013000 03:02 1205337
4d80d000-4d865000 r-xp 00000000 03:02 913797
/usr/lib/libfreetype.so.6.3.5
4d865000-4d86c000 rw-p 00057000 03:02 913797
4d86c000-4d87c000 r-xp 00000000 03:01 2534684 /lib/libz.so.1.2.1
4d87c000-4d87d000 rw-p 00010000 03:01 2534684 /lib/libz.so.1.2.1
4d87d000-4d88e000 r-xp 00000000 03:02 1205359
/usr/X11R6/lib/libXft.so.2.1.1
4d88e000-4d88f000 rw-p 00011000 03:02 1205359
4d88f000-4d896000 r-xp 00000000 03:02 1205373
/usr/X11R6/lib/libXrender.so.1.2.2
4d896000-4d897000 rw-p 00007000 03:02 1205373
4d897000-4d8bb000 r-xp 00000000 03:02 913898
/usr/lib/libfontconfig.so.1.0.4
4d8bb000-4d8be000 rw-p 00024000 03:02 913898
4d8bf000-4d8de000 r-xp 00000000 03:02 913799 /usr/lib/libexpat.so.0.4.0
4d8de000-4d8e0000 rw-p 0001e000 03:02 913799 /usr/lib/libexpat.so.0.4.0
4d8e0000-4d8e9000 r-xp 00000000 03:02 1205331
/usr/X11R6/lib/X11/locale/lib/common/xomGeneric.so.2
4d8e9000-4d8ea000 rw-p 00008000 03:02 1205331
4d8f3000-4d8fb000 r-xp 00000000 03:02 1205351
/usr/X11R6/lib/libXcursor.so.1.0
4d8fb000-4d8fc000 rw-p 00007000 03:02 1205351
4d8fc000-4d919000 r-xp 00000000 03:02 1205326
/usr/X11R6/lib/X11/locale/lib/common/ximcp.so.2
4d919000-4d91b000 rw-p 0001c000 03:02 1205326
4d91c000-4d91d000 r-xp 00000000 03:02 912268 /usr/lib/gconv/ISO8859-1.so
4d91d000-4d91e000 rw-p 00001000 03:02 912268 /usr/lib/gconv/ISO8859-1.so
Heap at VM Abort:
Heap
def new generation total 576K, used 129K [0x44750000, 0x447f0000,
0x44c30000)
eden space 512K, 24% used [0x44750000, 0x4476faa8, 0x447d0000)
from space 64K, 5% used [0x447d0000, 0x447d0d38, 0x447e0000)
to space 64K, 0% used [0x447e0000, 0x447e0000, 0x447f0000)
tenured generation total 3972K, used 3944K [0x44c30000, 0x45011000,
0x48750000)
the space 3972K, 99% used [0x44c30000, 0x4500a330, 0x4500a400,
0x45011000)
compacting perm gen total 4608K, used 4400K [0x48750000, 0x48bd0000,
0x4c750000)
the space 4608K, 95% used [0x48750000, 0x48b9c000, 0x48b9c000,
0x48bd0000)
Local Time = Mon Jun 28 16:23:42 2004
Elapsed Time = 5
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_04-b05 mixed mode)
---------------------------End of hs_err_XXX.log --------------
Previous Topic:Build Running/Complete API???
Next Topic:RC problems in general
Current Time: Tue Apr 29 01:47:59 EDT 2025
Powered by FUDForum. Page generated in 0.07638 seconds
