Re: Export as HTML in birt viewer ? [message #256598 is a reply to message #256586] |
Fri, 28 September 2007 16:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Stephane,
BIRT 2.2
If you use /preview instead of /frameset you should get the produced
html, and then you can just save the page.
Jason
Stéphane Bouchet wrote:
> Hi all,
> When using web viewer, how can i save the produced HTML ?
> i can export in PDF,DOC, but no HTML ?
> Stéphane
Re: Export as HTML in birt viewer ? [message #256655 is a reply to message #256651] |
Mon, 01 October 2007 14:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Stephane,
You can use the Engine API to do this, but without a code change to the
Viewer I do not see an easy way to export the report as html and save it.
Jason
> thanks, so i understand that there is actually no way to have HTML
> export option in the viewer.
> Jason Weathersby a écrit :
>> Stephane,
>> BIRT 2.2
>> Jason
>>> Hi all,
>>> Thanks,
>>> Stéphane
FUDForum. Page generated in 0.02899 seconds
