Home » Archived » BIRT » Null Report Parameter Passed to Data Set
Null Report Parameter Passed to Data Set [message #256497] Fri, 28 September 2007 03:22 Go to next message
Originally posted by: aituoklis.gmail.com
I found example (Bugzilla ID 182197) which illustrates handling a null
report parameter before using it in a data set parameter.
As I understood this workaround is used, because data set parameter can't
be null.
But sometimes you want to write something like this:
select *
from orderdetails
where (? is NULL OR CLASSICMODELS.ORDERDETAILS.ORDERNUMBER =? )
So we having the same result as in example, but
without using Birt scripting posibilities.
And it's working! So were is the problem? Problem is that J2EE server
(in my case JBoss 4.2.0GA) throwing errors like this:
org.eclipse.birt.data.engine.odaconsumer.ParameterMetaData
getRuntimeParameterType
SEVERE: Cannot get parameter type.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: Cannot get parameter
type.
SQL error #1: Unsupported feature
java.sql.SQLException: Unsupported feature
org.eclipse.birt.report.data.oda.jdbc.ParameterMetaData.getP arameterT
ype(ParameterMetaData.java:159)
So report is showing correct results, but J2EE server is throwing errors,
it's not critical, but not nice.
So my question is: is it planned to support null data set parameters in
BIRT? And if yes, so in which version?
Thank you in advance for answers.
Aivaras
Re: Null Report Parameter Passed to Data Set [message #256540 is a reply to message #256497] Fri, 28 September 2007 10:51 Go to previous message
Hi Aivaras,
It seems that NULL parameters might be handled differently in BIRT 2.2.1
based on this resolved bug...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=203100
Virgil Dodson
http://www.birt-echange.com
Aivaras Marcinkevicius wrote:
> report parameter before using it in a data set parameter. As I
> understood this workaround is used, because data set parameter can't be
> null. But sometimes you want to write something like this:
> select *
> from orderdetails
> without using Birt scripting posibilities. And it's working! So were is
> the problem? Problem is that J2EE server (in my case JBoss 4.2.0GA)
> parameter type.
> at
> errors, it's not critical, but not nice.
> Aivaras
Previous Topic:Query with argumentlist ; VALUE in ('A','B','C')
Next Topic:Websphere Memory utilization is HIGH (URGENT)
Current Time: Tue Jul 01 09:17:56 EDT 2025
Powered by FUDForum. Page generated in 0.07963 seconds
