Re: package explorer doesn't show source folders [message #256500 is a reply to message #256494] |
Fri, 16 May 2008 14:46 |
Felix,
Was this property on by default or had you previously selected it?
Paul,
In the org.eclipse.jet project checked out from CVS the src folder in
the Package Explore is hidden. Is that a related issue?
Felix Dorner wrote:
> It wasn't mylin. The project contains some jet templates, but also
> hand-written code. In the filters, the point "source folders from jet
> transformation projects" was checked...
> Felix
Re: package explorer doesn't show source folders [message #256515 is a reply to message #256508] |
Fri, 16 May 2008 15:02 |
Felix,
It's usually a bit confusing to have filters on by default because as a
user you might might not know about the option and might be thinking
something is wrong that you can't see the files...
Felix Dorner wrote:
> Ed Merks wrote:
>> Felix,
> Think it was on by default.
> Felix
FUDForum. Page generated in 0.08649 seconds
