package explorer doesn't show source folders [message #256491] |
Fri, 16 May 2008 06:36  |
Hey,
just had to try the fresh M7 packages, and additionally installed Mylin. I check
out my projects, and they appear in the package explorer, only that it does not
show the source folders. The folders are apparently there, shown in the "Java
Browsing" perspective, and the project is built too.
I guess it's mylin.. but have no idea how to make the folders appear in the
package explorer. )I already checked the "filters" but found nothing suspicious...
Thanks for helping,
Felix
Re: package explorer doesn't show source folders [message #256956 is a reply to message #256523] |
Wed, 21 May 2008 21:06  |
Felix:
JET turns it on by default. The assumption was that people using JET
wouldn't want to be bothered by the generated Java code, much as we aren't
bothered by the Java compilers generated .class files. Submit a bug if its
really bugging you.
Paul
"Felix Dorner" <felix_do@web.de> wrote in message
news:g0kcdl$or2$1@build.eclipse.org...
> Ed Merks wrote:
>> Felix,
>> It's usually a bit confusing to have filters on by default because as a
>> user you might might not know about the option and might be thinking
>> something is wrong that you can't see the files...
> Hey, I didn't turn it on...
FUDForum. Page generated in 0.12953 seconds
