Home » Modeling » GMF (Graphical Modeling Framework) » Setting dirty flag
Setting dirty flag [message #25300] Tue, 22 August 2006 07:12 Go to next message
Originally posted by: zsolt.sandor.gmail.com
Hi all!
I run into an other problem. We have a property dialog box
for every graphical element, which can be selected by the user
using the right mouse button -> context menu -> item sequence.
After the user press the ok on the dialog box, the data will
be copied to the representing emf model.
Before the user opens the dialog, we set the emf model regarding
to the graphical element:
- window variable is the graphical window
NodeImpl graphicalElement = (NodeImpl) mySelectedElement.getModel();
window.setModelFilter(graphicalElement.getElement());
window.setSize(580, 480);
shell.pack();
shell.open();
However the model change does not implies the change of the
dirty flag. Can we somehow force the diagram editor to set
the dirty flag?
Zsolti
Re: Setting dirty flag [message #25691 is a reply to message #25300] Tue, 22 August 2006 09:59 Go to previous messageGo to next message
Zsolt,
In the generated EMF editors, the dirty flag is based on the state of
the command stack, i.e, have any commands been executed (or undone)
since the last save/load. So maybe you aren't using a command to modify
the model's state?
Zsolt Sandor wrote:
> Hi all!
> for every graphical element, which can be selected by the user using
> shell.pack();
> shell.open();
> the dirty flag?
> Thanks:
> Zsolti
Re: Setting dirty flag [message #25737 is a reply to message #25691] Tue, 22 August 2006 10:05 Go to previous messageGo to next message
Yes, I don't use commands, because I don't need the
undo/redo support for my dialog boxes.
Re: Setting dirty flag [message #25874 is a reply to message #25737] Tue, 22 August 2006 10:31 Go to previous messageGo to next message
Zsolt,
Do you use the command stack at all? Changing the model without a
command will potentially invalidate the stack which relies on the fact
that all changes are done with commands and hence the model is in a
known state at the time of an undo. The solution to your problem is to
use commands to update the model state; a change recorder-based command,
like EMF's ChangeCommand, can be used to wrap your direct model changes
as a command...
Re: Setting dirty flag [message #25956 is a reply to message #25874] Tue, 22 August 2006 10:52 Go to previous message
Ahamm.... now, I understand the concept, thanks!
Previous Topic:Re: Please Help -Using EMFT Validation in GMF
Next Topic:MindMap Tutorial
Current Time: Mon Nov 03 10:56:06 EST 2025
Powered by FUDForum. Page generated in 0.04288 seconds
