Re: Newbie Install prob on Ubuntu "Hardy" [message #256479 is a reply to message #256463] |
Fri, 16 May 2008 04:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: codeslave.ca.ibm.com
Here's your problem:
java.fullversion=GNU libgcj 4.2.3 (Ubuntu 4.2.3-2ubuntu6)
You need to install a supported JVM: Sun, IBM, BEA, etc. GCJ will not work.
http://wiki.eclipse.org/IRC_FAQ#I_just_installed_Eclipse_on_ Linux.2C_but_it_does_not_start._What_is_the_problem.3F
Nick
Tom Brander wrote:
> Any help appreciated I searched for install problems..no luck
> Ok, I'm really new, Just started Hardy Linux (installed in a dual boot
> WUbi configuration)(new to that) Loaded MYsql(new to that) And loaded
> Eclipse (don't know much here either nor Java) But that is what I'm
> trying to learn....
> With the Default install I don't seem to be getting the help system?
> I ran the update function and got the c++ help system installed but
> nothing else.
> Here is a part of the error log from the initial install.
> Thanks!
> Tom
> !SESSION 2008-05-08 17:05:45.781
> eclipse.buildId=M20070212-1330
> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
> Command-line arguments: -os linux -ws gtk -arch x86
> !ENTRY org.eclipse.osgi 2 1 2008-05-08 17:05:57.039
> !MESSAGE NLS missing message: initializer_error in:
> org.eclipse.core.internal.runtime.messages
> !ENTRY org.eclipse.osgi 2 1 2008-05-08 17:05:57.040
> !MESSAGE NLS missing message: fileInitializer_fileNotFound in:
> !MESSAGE NLS missing message: fileInitializer_IOError in:
> !ENTRY org.eclipse.osgi 2 1 2008-05-08 17:05:57.041
> !MESSAGE NLS missing message: fileInitializer_missingFileName in:
> !ENTRY org.eclipse.update.core 4 0 2008-05-08 17:09:10.830
> !MESSAGE Cannot install featureorg.eclipse.sdk.samples 3.2.0
> [java.lang.reflect.InvocationTargetException]
> !STACK 0
> at
> org.eclipse.update.internal.operations.BatchInstallOperation .execute(BatchInstallOperation.java:104)
> at
> org.eclipse.update.standalone.InstallCommand.run(InstallComm and.java:183)
> at
> org.eclipse.pde.internal.ui.samples.ShowSampleAction$2.run(S howSampleAction.java:155)
> at
> org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
> Caused by: org.eclipse.core.runtime.CoreException: Unable to complete
> action for feature "Eclipse SDK Samples" due to errors.
Re: Newbie Install prob on Ubuntu "Hardy" [message #256581 is a reply to message #256543] |
Sat, 17 May 2008 05:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Well, I haven't stepped up to the latest Ubuntu yet (I use Antix 7 on
one machine and MEPIS 6 on my other), but I have no problems running
Eclipse.
Of course I don't use the .deb packages, I just download the latest SDK
..tar.gz from Eclipse.org [1] and unpack that. (If you installed a .deb
that does not include doc or source, you need to grab that package
too... or get the full SDK instead, which includes runtime, source, and
doc for JDT, PDE, CVS, etc.) Chances are there are multiple packages for
your distro in the same way that you can install .debs for Java SDK,
runtime, sources, or doc (or a combination).
[1] http://download.eclipse.org/eclipse/downloads/
I generally use a .desktop shortcut which runs something like this:
/home/nickb/eclipse/eclipse34/eclipse -showLocation -vm
/opt/sun-java2-6.0/bin/java -data /home/nickb/eclipse/workspace2 -clean
-vmargs -Xms128M -Xmx256M -XX:PermSize=128M -XX:MaxPermSize=256M
Oh, and FYI, there's also http://help.eclipse.org/stable/ (Eclipse 3.4)
and http://help.eclipse.org/help33/ (Eclipse 3.3) if you want the same
information online.
Nick
Tom Brander wrote:
> Nick,
> Thank you for the quick reply,
> I think I got the right Java installed now but my config is still way
> messed up, no help files for java...through eclipse.
> just to be on the safe side i de-installed and re installed Eclipse
> after "fixing" the Java install.. still no help files.. and when I try
> to do most sorts of updates through updates in eclipse i get
> configuration errors...
> error file as follows,
> !SESSION 2008-05-16 15:45:55.621
> java.version=1.6.0_06
> java.vendor=Sun Microsystems Inc.
> !ENTRY org.eclipse.osgi 2 1 2008-05-16 15:45:59.858
> !ENTRY org.eclipse.osgi 2 1 2008-05-16 15:45:59.859
> !ENTRY org.eclipse.osgi 2 1 2008-05-16 15:45:59.860
Re: Newbie Install prob on Ubuntu "Hardy" [message #256634 is a reply to message #256630] |
Sat, 17 May 2008 15:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: wegener.cboenospam.com
Tom Brander wrote:
> Well... accurate but over my head,, I used the so called distro's in the
> hardy library, I did get some errors... but I'm such a newbie at Linux I
> don't know where to go from here.. I'm about to just reinstall on
> Windows.... What I was hoping to avoid...
> So the file not found messages I posted cannot help to find and
> straighten out the install? Not that I know how to do this in Linux..
I would avoid the Eclipse packages from the Hardy repositories. You can
download Eclipse for the eclipse.org web site as a single tar file.
Installation requires untaring the file and running the eclipse executable.
The Hardy packages are maintained by Ubuntu developers. If you have
problems with them, you will probably have to post on the Ubuntu forums.
FUDForum. Page generated in 0.08442 seconds
