Home » Eclipse Projects » Eclipse Platform » Debug performance
Debug performance [message #25288] Wed, 30 April 2003 22:07 Go to next message
Originally posted by: rnaranjo1.earthlink.net
I am running WSSD 5.0. I have a problem in that it takes me about ~4 min to
launch a debug instance for plugin development debugging. Does anyone know
what the problem could be? My initial startup time for WSSD is not that bad
so what is happening with the startup of the debug instance?
Rosa
Re: Debug performance [message #25732 is a reply to message #25288] Thu, 01 May 2003 11:22 Go to previous messageGo to next message
Originally posted by: jed_anderson.us.ibm.com
Rosa,
Does it take four minutes to attach? Or does it take four minutes for
the workbench to come up?
If it takes four minutes for the workbench to come up, the time is most
likely spent loading plugins. You can try reducing the amount of work
you do in your Plugin.startup() method.
Does this help any?
jkca
> Rosa
Re: Debug performance [message #27385 is a reply to message #25732] Fri, 02 May 2003 09:22 Go to previous messageGo to next message
No not really, because it does not matter what plugin I am developing it is
just the debug instance. Other times it has not been that bad like just
after a reinstall of WSSD but over time it gets progressively worse and it
is impossible to efficiently use this method for debugging plugins.
Thanks, Rosa
"Jed Anderson" <jed_anderson@us.ibm.com> wrote in message
news:b8re4h$1qm$1@rogue.oti.com...
> Rosa,
> Does this help any?
> jkca
min to
know
bad
> > Thanks,
> > Rosa
Re: Debug performance [message #27397 is a reply to message #27385] Fri, 02 May 2003 12:18 Go to previous message
Rosa,
In your Run-time Workbench, do you have a lot of
perspectives/views/editors active that have to be restored on startup?
For example, if you shutdown Eclipse with a Heirarchy View open, the
heirarchy is re-calculated on startup. If you have a particularly large
heirarchy this can slow startup significantly.
As a test, launch your Run-time Workbench, close all of the
perspectives, shutdown, and restart. If the workbench comes up quickly,
you know that plugin initialization or UI state restoring is to be
blamed for the slowdown.
Hope this helps (because if it doesn't... *shrug*)! :)
jkca
> Thanks, Rosa
>>Rosa,
>>Does this help any?
>>jkca
> min to
> know
> bad
>>>Thanks,
>>>Rosa
Previous Topic:How to replace/remove workbench menu items ?
Next Topic:IMemento in a standard class
Current Time: Wed Apr 16 11:39:45 EDT 2025
Powered by FUDForum. Page generated in 0.06300 seconds
