image programmatically [message #255909] |
Fri, 21 September 2007 07:07  |
I have an image item in report and want to set/create it programmatically.
<image name="someImage" id="16">
<property
name="eventHandlerClass">MyImageEventHandler</property>
</image>
On image event handler (MyImageEventHandler -> IImageEventHandler), I am
doing something like this:
public void onRender(IImageInstance image, IReportContext reportContext)
byte[] imageBuffer = .....
image.setData(imageBuffer);
Though this method executes but in the end, report doesn't contain any
image. I am just wondering, do I have to something more or may be in
some different way?
Any suggestions?
Thanks.
Re: image programmatically [message #255918 is a reply to message #255909] |
Fri, 21 September 2007 12:03   |
PC,
What selection did you use (URI, file, Embedded, dynamic?)
If you are using a byte array in 2.2 this should be set to dynamic, URI
will not work.
Here is an example of a test image handler.
I put this in for my settings for the image
<image id="60">
<property name="eventHandlerClass">myImageHandler</property>
<property name="source">expr</property>
<expression name="valueExpr">row["dummy"]</expression>
</image>
Jason
import
org.eclipse.birt.report.engine.api.script.eventadapter.Image EventAdapter;
import org.eclipse.birt.report.engine.api.script.instance.IImageIns tance;
import org.eclipse.birt.report.engine.api.script.IReportContext;
import java.io.*;
public class myImageHandler extends ImageEventAdapter {
public void onCreate(IImageInstance image, IReportContext reportContext) {
try{
File file = new File("c:/temp/test.png");
FileInputStream ist = new FileInputStream(file);
int lengthi = (int)file.length();
ByteArrayOutputStream bytesa = new ByteArrayOutputStream( lengthi);
int c;
while((c=ist.read()) != -1){
bytesa.write(c);
ist.close();
image.setData(bytesa.toByteArray());
}catch( Exception e){
e.printStackTrace();
public void onRender(IImageInstance image, IReportContext reportContext) {
// TODO Auto-generated method stub
super.onRender(image, reportContext);
PC wrote:
> <property
> </image>
> @Override
> some different way?
> Any suggestions?
> Thanks.
Re: image programmatically [message #255926 is a reply to message #255918] |
Fri, 21 September 2007 13:16  |
Thanks Jason.
I am using BIRT 2.2.
I was not using source in image i.e. no source like expr, I thought I
don't need it, if I am seting programmatically.
Now, as per your suggestion I have changed it to:
<expression name="valueExpr">"dummy"</expression>
</image>
and it worked.
I didn't use row otherwise it was complaining about row variable, but
that also worked as per:
<method name="onPrepare"><![CDATA[var row = 0;]]></method>
</image>
Thanks for your time & help.
Jason Weathersby wrote:
> PC,
> will not work.
> <image id="60">
> </image>
> Jason
> import
> import java.io.*;
> @Override
> reportContext) {
> try{
> int c;
> bytesa.write(c);
> ist.close();
> @Override
> reportContext) {
> PC wrote:
>> programmatically.
>> <property
>> </image>
>> am doing something like this:
>> @Override
>> reportContext)
>> some different way?
>> Any suggestions?
>> Thanks.
FUDForum. Page generated in 0.06606 seconds
