Home » Archived » BIRT » [Ubuntu 7.04 Linux] Eclipse standalone with BIRT: not visible
[Ubuntu 7.04 Linux] Eclipse standalone with BIRT: not visible [message #255839] Wed, 19 September 2007 10:13
Originally posted by: peter.koster.spamtrap.trapspam.industrial-tsi.com
Hi all,
I use to work with BIRT 2.2 within Eclipse 3.3 (Europa) on windows XP. No
problems. I got the chance to try it on Ubuntu Linux as well.
I didnt make use of the Ubuntu repositories / Synaptic; I used the simple
but in this case better way: standalone version eclipse-java-europa-linux-
gtk.tar.gz, made sure all dependencies were available i.e. Java runtime
environments etc etc.... and finally I installed birt-report-
framework-2_2_0.zip (being platform independent this should be the right
zip to unzip into the plugins folder)
But whatever I try, i cannot make the reporting perspektive visible. Also
file>new>other>other: no birt entry. I checked the faq: given solution
doesn't apply.
Anyone?
tia, HP
Software lifecycle support --- http://www.industrial-tsi.com
Eclipse RCP training >>> http://tinyurl.com/3d7ngo
Previous Topic:binding data to a crosstab from a different dataset
Next Topic:using temporary db tables in birt?
Current Time: Wed Apr 16 02:10:21 EDT 2025
Powered by FUDForum. Page generated in 0.08807 seconds
