Home » Language IDEs » Java Development Tools (JDT) » Migration from Polarion version to Eclipse version fails with Eclipse 3.3
Migration from Polarion version to Eclipse version fails with Eclipse 3.3 [message #255592] Wed, 13 August 2008 11:46 Go to next message
I'm still using Eclipse 3.3 and wanted to upgrade Subversive from the
Polarion version (SVN Team Provider 1.1.9.02) to the most current Eclipse
version (Subversive SVN Team Provider 0.7.3). I followed the migration
instructions
http://www.eclipse.org/subversive/documentation/gettingStart ed/aboutSubversive/update_polarion.php
and did the following steps in this order:
1.) Install Subversive SVN Team Provider 0.7.3 via archived update site
downloaded from
http://www.eclipse.org/downloads/download.php?file=/technolo gy/subversive/0.7/builds/Subversive-incubation-0.7.3.I200808 14-1500.zip
Note that the Polarion version was not uninstalled (as the instructions
document indicates).
2.) Restart Eclipse and try to click 'Help > Subversive > Migrate Projects
and Settings'. The result is that a dialog window pops up saying "The chosen
operation is not currently available". In the error log appears a new event
and stack trace as appended at the end of this message.
I also tried to disable the Polarion version (including all its
dependencies), restart Eclipse, and try the same action. The effect is the
same.
Any hints what I can do now?
Best,
Thorsten
Error
Wed Aug 13 17:24:35 CEST 2008
Plug-in org.eclipse.team.svn.ui was unable to load class
org.eclipse.team.svn.ui.debugmail.MigrateToEclipse.
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
An error occurred while automatically activating bundle
org.eclipse.team.svn.ui (628).
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
org.eclipse.team.svn.mylyn.SVNActiveChangeSetProvider.getAct iveChangeSetManager(SVNActiveChangeSetProvider.java:25)
org.eclipse.mylyn.internal.team.ui.FocusedTeamUiPlugin.addAc tiveChangeSetProvider(FocusedTeamUiPlugin.java:124)
org.eclipse.mylyn.internal.team.ui.FocusedTeamExtensionPoint Reader.readExtensions(FocusedTeamExtensionPointReader.java:5 0)
org.eclipse.mylyn.internal.team.ui.FocusedTeamUiPlugin$1.run (FocusedTeamUiPlugin.java:77)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:129)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Caused by: org.osgi.framework.BundleException: The activator
org.eclipse.team.svn.ui.SVNTeamUIPlugin for bundle org.eclipse.team.svn.ui
is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
... 38 more
Caused by: java.lang.NoClassDefFoundError:
org/eclipse/team/svn/core/operation/IActionOperation
at org.eclipse.team.svn.ui.SVNTeamUIPlugin.<init>(SVNTeamUIPlugin.java:54)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:136)
... 43 more
Caused by:
org.eclipse.team.svn.core (624).
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.team.core.RepositoryProvider.newProvider(Reposit oryProvider.java:706)
org.eclipse.team.core.RepositoryProvider.mapNewProvider(Repo sitoryProvider.java:162)
org.eclipse.team.core.RepositoryProvider.mapExistingProvider (RepositoryProvider.java:235)
org.eclipse.team.core.RepositoryProvider.getProvider(Reposit oryProvider.java:577)
org.eclipse.team.svn.ui.decorator.wrapper.AbstractDecoratorW rapper.isSVNShared(AbstractDecoratorWrapper.java:39)
org.eclipse.team.svn.ui.decorator.wrapper.ProjectDecoratorWr apper.decorate(ProjectDecoratorWrapper.java:27)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.decorate(LightweightDecoratorDefinition.java:253)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er$LightweightRunnable.run(LightweightDecoratorManager.java: 71)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.decorate(LightweightDecoratorManager.java:336)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.getDecorations(LightweightDecoratorManager.java:322)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.ens ureResultCached(DecorationScheduler.java:369)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.run (DecorationScheduler.java:329)
Caused by: org.osgi.framework.BundleException: Exception in
org.eclipse.team.svn.core.SVNTeamPlugin.start() of bundle
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1018)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
... 30 more
Caused by: java.io.StreamCorruptedException: invalid type code: 00
at java.io.ObjectInputStream.readObject0(Unknown Source)
at java.io.ObjectInputStream.readObject(Unknown Source)
org.eclipse.team.svn.core.svnstorage.AbstractSVNStorage.load LocationsFromFile(AbstractSVNStorage.java:548)
org.eclipse.team.svn.core.svnstorage.AbstractSVNStorage.init ializeImpl(AbstractSVNStorage.java:402)
org.eclipse.team.svn.core.svnstorage.SVNRemoteStorage.initia lize(SVNRemoteStorage.java:163)
at org.eclipse.team.svn.core.SVNTeamPlugin.start(SVNTeamPlugin. java:154)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
... 35 more
Re: Migration from Polarion version to Eclipse version fails with Eclipse 3.3 [message #255599 is a reply to message #255592] Wed, 13 August 2008 12:09 Go to previous message
uuups, posting was not intended for this group ...
Thorsten M
Previous Topic:code to make an editor appear and display a given method
Next Topic:Looking for a way to recursively dump object references to a file
Current Time: Wed Apr 16 02:09:16 EDT 2025
Powered by FUDForum. Page generated in 0.07360 seconds
