The AXIS engine could not find a target service to invoke! targetService is null [message #255425] |
Fri, 14 September 2007 03:56  |
Originally posted by: teemu.turkia.propentus.fi
Hi!
I deployed BIRT 2.2.0 to WebSphere 6.0. index.jsp shows fine, but when I try
to run the test report, I get this error message:
null.
When I click "Show Exception Stack Trace", it shows only empty Stack Trace.
EAR classloader mode is set to parent last and WAR class loader policy is
set to Application. Also the web modules class loader mode is set to parent
last.
I have tried the default library structure and I also tried to remove emf
jars from platform/plugins directory (+ moved org.eclipse.emf_2.2.0...jar to
WEB-INF/lib folder) as described in
http://wiki.eclipse.org/Birt_WebSphere_Deployment. Nothing seems to help.
Any ideas what I am doing wrong?
Teemu Turkia
Re: The AXIS engine could not find a target service to invoke! targetService is null [message #255433 is a reply to message #255429] |
Fri, 14 September 2007 04:24   |
Originally posted by: mil.methodpark.de
Argh, I made a stupid mistake: I forgot to copy some config files
(server-config.wsdd, ...) to the appropriate folder of my webapp.
It works fine now!
Greetings,
Matthias
"Meandron" <mil@methodpark.de> schrieb im Newsbeitrag
news:fcdf8t$er4$1@build.eclipse.org...
> I have the same problem with tomcat 6...
> Greetings,
> Matthias
> "Teemu Turkia" <teemu.turkia@propentus.fi> schrieb im Newsbeitrag
> news:fcdev3$dnd$1@build.eclipse.org...
>> Hi!
>> try to run the test report, I get this error message:
>> is null.
>> Trace.
>> parent last.
>> to WEB-INF/lib folder) as described in
>> Thanks,
>> Teemu Turkia
FUDForum. Page generated in 0.03592 seconds
