Source plugins for RSE [message #25187] |
Sun, 27 July 2008 09:28  |
I just installed RSE from the Ganymede update site. To learn what's going
on behind the scenes I wanted to import the RSE source code using
Import/Plugins and Fragments/Projects with source folders. However, it
seems that the required source plugins are missing (some of the imported
projects do not contain source files and consequently compilation errors
occur).
- Can I install the source plugins separately from somewhere?
- If not, is this absence of source plugins an omission, that is, should I
open a "feature request" for it?
Jan Ploski
Re: Source plugins for RSE [message #25232 is a reply to message #25187] |
Mon, 28 July 2008 03:04  |
Originally posted by: r.gerganov.prosyst.bg
Hi Jan,
If you want to obtain the sources, you need to install the RSE Extender SDK which is not included in
the Ganymede update site. You can either get it from the TM update site [1] or download it from the
project downloads page [2].
[1] http://download.eclipse.org/dsdp/tm/updates/3.0/
[2] http://download.eclipse.org/dsdp/tm/downloads/drops/R-3.0-20 0806202130/
Rado
Jan Ploski wrote:
> going on behind the scenes I wanted to import the RSE source code using
> occur).
> I open a "feature request" for it?
> Jan Ploski
Re: Source plugins for RSE [message #576249 is a reply to message #25187] |
Hi Jan,
Rado
Jan Ploski wrote:
> occur).
> Jan Ploski
FUDForum. Page generated in 0.03209 seconds
