same preferences for team members [message #255260] |
Thu, 24 June 2004 11:13 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: pascal.naef.bison-group.com
Hello
I want to make sure that every team member has the same preferences and
can't chance it.
How can I do this?
My concept was to overwrite the plug-in settings with the command line
argument -pluginCustomization but that chances only the default values. So
the user modified setting won't be overwritten.
How can I forbid the overwriting? Is it possible to lock some preferences
pages like java->compiler. Does anybody have a tip or an other idea?
Pascal
Re: same preferences for team members [message #255274 is a reply to message #255260] |
Thu, 24 June 2004 13:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: akiezun.cutthis.mit.this.edu.andthis
Pascal Naef wrote:
> Hello
> can't chance it.
wow, pretty nasty workplace you're in.
i guess you could remove preference page extensions from plugin.xml
files. that should do it.
a.
Re: same preferences for team members [message #255282 is a reply to message #255274] |
Thu, 24 June 2004 13:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
adam kiezun wrote:
> Pascal Naef wrote:
>> Hello
>> can't chance it.
> a.
right, but what if they go, download eclipse and put the real plugin.xml
files? idea: block internet access.
they could bring them on cd's! idea: search them upon entry to the building.
well, they could memorize the darn extensions! 2 options: remove the
classes too and build eclipse from source or lobotomize team members daily.
now those liberal sissies won't be able to change the color of they
current line highlighter.
cheers :)
a.
Re: same preferences for team members [message #255312 is a reply to message #255282] |
Thu, 24 June 2004 14:21 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks for your help. It's a possible solution.
The workplace isn't nasty. I'm looking only for solution how I can
configure eclipse very easy and automatically, example a ini-file (for
pluginCustomization) in cvs. When everybody can change his preferences a
setting update doesnt work.
adam kiezun wrote:
> adam kiezun wrote:
> > Pascal Naef wrote:
> >> Hello
> >> can't chance it.
> > a.
> cheers :)
> a.
Re: same preferences for team members [message #255538 is a reply to message #255312] |
Fri, 25 June 2004 07:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> preferences a setting update doesn
Re: same preferences for team members [message #255574 is a reply to message #255538] |
Fri, 25 June 2004 11:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
I would like to overwrite the customized preferences and not the defaults.
For that I need a plug-in, which overwrites the entries in the directory
workspace/.metadata/.plugin. So the user has the default preferences after
every start-up.
Does a plugin with this functionality already exist?
Pascal
> > preferences a setting update doesnt work.
> You can provide your own primary feature / product which can override
> several default preferences with new default settings. Then this feature can
> be fetch by your developers from an internal update site or you can deploy
> it together with Eclipse.
> Of course every team member is still able to change the preferences of their
> installation the way they like. But for this I suggest a bug-piggy-bank.
> It's _very_ worth while. ;)
> Cu, Gunnar
FUDForum. Page generated in 0.03426 seconds
