Home » Archived » BIRT » Query with argumentlist ; VALUE in ('A','B','C')
Query with argumentlist ; VALUE in ('A','B','C') [message #255094] |
Tue, 11 September 2007 18:54 |
Klaasjan Tukker Messages: 16 Registered: July 2009 |
Junior Member |
I am looking for a way to bind a "list of values" separated by "," to a
query.
The users enters a list of strings like "A,B,C,D" and the query has to be
expanded to:
SELECT *
FROM myTable
WHERE VALUE in ('A','B','C',D');
How can this be achieved? I tried the regular binding way but that results
in VALUE in ('A,B,C,D')
With kind regards,
Klaasjan
Re: Query with argumentlist ; VALUE in ('A','B','C') [message #255364 is a reply to message #255094] |
Thu, 13 September 2007 19:26 |
Klaasjan,
You can do this in the beforeOpen script of the data set.
this.queryText = this.queryText + " Value in ('" + param["one"] + "','"
+ param["two"] + "')";
Jason
Klaasjan Tukker wrote:
> query.
> expanded to:
> SELECT *
> FROM myTable
> With kind regards,
> Klaasjan
Re: Query with argumentlist ; VALUE in ('A','B','C') [message #256396 is a reply to message #255364] |
Wed, 26 September 2007 19:45 |
Originally posted by: edk.simsol.com
That looks like it works if you have a parameter for each value. But
how would you do it for one parameter with a list of comma separated
values which may be from 1 to n of values
param=A,B,C,D
Ed
Jason Weathersby wrote:
> Klaasjan,
> Jason
>> a query.
>> be expanded to:
>> SELECT *
>> FROM myTable
>> results in VALUE in ('A,B,C,D')
>> With kind regards,
>> Klaasjan
Re: Query with argumentlist ; VALUE in ('A','B','C') [message #256528 is a reply to message #256396] |
Fri, 28 September 2007 14:38 |
Ed,
You should be able to do this:
this.queryText =this.queryText + " Value in('" + params["onlyone"] + "')";
Jason
> param=A,B,C,D
> Ed
>> Klaasjan,
>> "','" + param["two"] + "')";
>> Jason
>>> Hi,
>>> a query.
>>> to be expanded to:
>>> SELECT *
>>> FROM myTable
>>> With kind regards,
>>> Klaasjan
Current Time: Thu Jul 18 09:05:34 GMT 2024
Powered by FUDForum. Page generated in 0.03922 seconds
