jdk [message #254997] |
Mon, 14 July 2008 15:45 |
Originally posted by: faithict.yahoo.com
When I tried to import a file from a databse, i keep on getting this error
box and then eclipse will exit. Can anyone please advice what's wrong with
this? thank you!
C:\jdk1.6.0_10\bin\javaw.exe
-jar C:\eclipse\startup.jar
-data C:\eclipse_workspace
-os win 32
-ws win32
-arch x86
-launcher C:\eclipse\eclipse.exe
-name Eclipse
-showsplash 600
-exitdata d1c_70
-vm C:\jdk1.6.0_10\bin\javaw.exe
-vmargs
Re: jdk [message #255001 is a reply to message #254997] |
Mon, 14 July 2008 15:59 |
Walter Harley Messages: 847 Registered: July 2009 |
"tracy" <faithict@yahoo.com> wrote in message
news:a0ac4c34fd52d80a350e2862b370da5b$1@www.eclipse.org...
> this? thank you!
> -os win 32
> -ws win32
> -arch x86
> -name Eclipse
> -showsplash 600
> -exitdata d1c_70
> -vmargs
Hmm, I'm not sure why you're posting this in the eclipse.tools.jdt
newsgroup - does it have anything to do with JDT? I'm adding
eclipse.newcomer to the newsgroups list, as that is often a good starting
point if you're not sure where to ask a question.
Anyway, to help, we'll probably need some more info. Here are a few
questions to get you started:
1. Has this ever worked in the past? If so, what has changed?
2. When you say "import a file from a database", what do you mean by that?
Can you be very specific about exactly what steps you took, what kind of
file, what kind of database, etc.?
3. What version of Eclipse are you using?
4. Do you have any third-party (non-Eclipse) plugins installed?
5. Is there anything in the error log (look in your workspace, in
..metadata/.log, or just bring up the PDE Runtime -> Error Log view)?
6. Is Eclipse otherwise working normally?
7. Have you tried any other debugging or troubleshooting, and if so, what
did you learn?
Thanks!
Re: jdk [message #255004 is a reply to message #255001] |
Mon, 14 July 2008 17:02 |
Hello, Thank you so much for replying me. I am sorry I posted it at the
wrong place. Do you want me to move it to the newcomer newsgroup? Thank
you! Below are the answers to your questions.
Yes this had worked before but after one month of not touching this
project, and when i tried to run it again, it is giving me error.
I am importing file from Oracle
3. What version of Eclipse are you using? 3.2
No I do not have
I saw that there is a NullPpointerException error in it. I had attached
the error below. it.
!ENTRY org.eclipse.ui 4 0 2008-07-14 10:48:07.236
!MESSAGE java.lang.NullPointerException
!STACK 0
at A.A.A.A.B.A.K.K.dispose(y:119)
at org.eclipse.jface.wizard.Wizard.dispose(Wizard.java:198)
at org.eclipse.jface.wizard.WizardDialog.hardClose(WizardDialog .java:728)
at org.eclipse.jface.wizard.WizardDialog.close(WizardDialog.jav a:407)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window .java:736)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:68 2)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:159)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:952)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:937)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations. java:257)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.jav a:1606)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3248 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1539)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:1634)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4025 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:185 1)
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:438)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3334 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:19 32)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2966)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.ui.actions.ImportResourcesAction.run(ImportResou rcesAction.java:159)
org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEv ent(BaseSelectionListenerAction.java:168)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1930)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:422)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Yes other than this the Eclipse is working properly.
did you learn?
No i haven't tried any debugging or troubleshooting.
Thank you!
FUDForum. Page generated in 0.03636 seconds
