Birt all in one 2.2.0 installs 1.0.1??? [message #254962] |
Tue, 11 September 2007 02:56 |
Originally posted by: not.areal.email
I downloaded and unzipped birt all in one 2.2.0 and have build several
reports that preview ok in the designer. However none of the reports run
when deployed. After wasting a couple of days on this I finally noticed
that the advanced pane of the designer property tab shows this:
Eclipse BIRT Designer Version 1.0.1 Build <20051130-1157>
So, why? The updater does not work, some required items are not found.
Argh.
Re: Birt all in one 2.2.0 installs 1.0.1??? [message #255508 is a reply to message #254962] |
Fri, 14 September 2007 15:35 |
In article <MPG.214fa3ab94ffe595989682@news.eclipse.org>,
not@areal.email says...
> Argh.
It would be nice if someone who is familiar with birt would respond to
this. If the all in one birt installs an older, broken birt, then it
should be taken down. It's not a good intro to birt, which I can see has
had a lot of work put in to it. If the birt 2.2.0 all in one is supposed
to install birt 1.0.1, it'd be interesting to hear why, especially since
it seems to creat problematic reports.
FUDForum. Page generated in 0.02846 seconds
