Re: Can't see Java templates in Ganymede [message #254850 is a reply to message #254825] |
Tue, 08 July 2008 08:49 |
Originally posted by: benno_baumgartner.ch.ibm.com
Mike Bishop wrote:
> After having installed the Ganymede release, I can no longer see my Java
> template preferences via Java -> Editor -> Templates. Instead, I see an
> error dialog stating "The currently displayed page contains invalid
> values." I was able to see and edit the templates in the previous
> version. I've seen references to this message in other posts, but not
> regarding templates. Even then, I haven't been able to figure out how
> those issues were solved. Has anyone else seen this particular problem
> and been able to resolve it? Thanks.
> Mike
Hi Mike
Please open a bug against JDT/Text and attach the corresponding stack
trace which you will find in your Error Log View.
As a workaround you can use the new Templates View.
HTH
Benno
FUDForum. Page generated in 0.03314 seconds
