Home » Eclipse Projects » Eclipse Platform » Internation chars become ? after saved/closed and reopened
Internation chars become ? after saved/closed and reopened [message #25084] Wed, 30 April 2003 17:15 Go to next message
Originally posted by: emerson.tre-sc.gov.br
I'm using Suse 8.1 linux and eclipse 2.1 final release GTK.
Sometime ago i post a question about using portuguese chars in motif
version (eg: çéá, if you can see :), becouse i caouldn't type these
kind of chars. I solved this changing to GTK version. A while ago I
noticed that as the typing was working all right, when the file is saved,
closed and reopened, the portuguese chars became all '?' char. ANd i hate
using those "Ó" char's, what is terrible :)
Does anyone had this problem before or could help me on that???
Thanks in advance
Emerson Cargnin
Re: Internation chars become ? after saved/closed and reopened [message #25208 is a reply to message #25084] Wed, 30 April 2003 17:43 Go to previous messageGo to next message
Originally posted by: veronika_irvine.oti.com
Sounds like an encoding problem when the file saved.
Try the following:
1)In a shell, type 'locale' to see what the encoding is in the OS
2) In eclipse, there are two places where the enconding is set.
Check Window -> Preferences -> Workbench -> Editors
Check Edit-> Encoding
ISO-8859-1 or Latin1 should work for Portuguese.
"Emerson Cargnin" <emerson@tre-sc.gov.br> wrote in message
news:b8pedu$orb$1@rogue.oti.com...
> using those "&Oacute;" char's, what is terrible :)
> Thanks in advance
> Emerson Cargnin
Re: Internation chars become ? after saved/closed and reopened [message #27594 is a reply to message #25208] Mon, 05 May 2003 13:38 Go to previous message
it appears that locale is not configured. when i typed locale it gave me :
LANG=POSIX
LC_CTYPE="POSIX"
LC_NUMERIC="POSIX"
LC_TIME="POSIX"
LC_COLLATE=POSIX
LC_MONETARY="POSIX"
LC_MESSAGES="POSIX"
LC_PAPER="POSIX"
LC_NAME="POSIX"
LC_ADDRESS="POSIX"
LC_TELEPHONE="POSIX"
LC_MEASUREMENT="POSIX"
LC_IDENTIFICATION="POSIX"
LC_ALL=
thanks veronika, i should have search a little bit more : )
other maybe related problem :
when using replace Ant task, it looses the special chars, unless i use
explicitly the encoding="iso-8859-1" property in each replace task, is
there a way to get it done without it?
and thanks for your reply.
Emerson
> Try the following:
> > Thanks in advance
> > Emerson Cargnin
Previous Topic:NoClassDefFoundError on new InitialContex()
Next Topic:dosplaying error icons for files
Current Time: Mon Nov 03 14:43:26 EST 2025
Powered by FUDForum. Page generated in 0.02917 seconds
