Re: Eclipse 3.4 RC1 crashes [message #253730 is a reply to message #253723] |
Tue, 03 June 2008 14:59 |
ying Messages: 19 Registered: July 2009 |
Junior Member |
Felix Dorner wrote:
> yinglcs wrote:
>> I am running eclipse 3.4 RC1 on ubuntu on jdk 1.6.5.
> If you dont neeed anything special, you could also download RC3 SDK from
> their site and install whatever else you need via the p2 update manager.
>> I create a project in eclipse. But as soon as I build the project
>> (press the Build icon) or even run the ant script in my project,
>> eclipse just crashes wiht no waring. And I look for .log file, it does
>> not create one.
> Sure theres no .log file
> yourworkspace/.metadata/
> Felix
This is the only thing I got:
more .log
!SESSION 2008-06-03 14:57:31.943
eclipse.buildId=I20080516-1333
java.version=1.6.0_05
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.ui.workbench 2 0 2008-06-03 14:58:56.248
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2008-06-03 14:58:56.248
!MESSAGE Conflict for 'org.eclipse.wst.sse.ui.format':
HandlerActivation(commandId=org.eclipse.wst.sse.ui.format,
handler=org.eclipse.wst.sse.ui.internal.handlers.FormatHandl er,
expression=org.eclipse.core.internal.expressions.ReferenceExpression@d4f
4315e,sourcePriority=1073741824)
expression=org.eclipse.core.internal.expressions.ReferenceExpression@429
a8fde,sourcePriority=1073741824)
Can you please tell me how to fix it?
Thank you.
FUDForum. Page generated in 0.02923 seconds
