Re: Query Timeout [message #253752 is a reply to message #253693] |
Tue, 28 August 2007 19:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Nicolas,
Look at the property binding tab of the data set.
Jason
Nicolas wrote:
> Hello,
> I'd like to set a timeout on my request.
> But I can't find how to do this.
> I find that the class CallStatement, used in the data.oda.jdbc plugin,
> can handle a property "queryTimeOut" which seems excatly what I want.
> But I don't find how to set it.
> Thanks
> (I'm using Birt engine 2.2)
> Nicolas
Re: Query Timeout [message #253808 is a reply to message #253752] |
Wed, 29 August 2007 07:28 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Pierre-Yves Chauveau![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=postmaster%40py-code.com) Messages: 53 Registered: July 2009 |
Member |
Thanks.
I don't know how I missed it...
So now an other question :-)
For one dataset, I set the query time out property.
But when I look to the xml source of the report, I see this property in
the "global" PropertyBindings, near odaURL odaUSer, etc...
and not in the property binding of the dataset.
So if I set the query timeout for my N datasets, I see N properties
"queryTimeOut" (and N "queryText") in the "global" property binding.
Is it normal?
Should the property "queryTimeOut" be in the property bindings of each
dataset?
Thanks a lot.
Nicolas
Jason Weathersby wrote:
> Nicolas,
> Jason
> Nicolas wrote:
>> Hello,
>> Thanks
>> Nicolas
Re: Query Timeout [message #253846 is a reply to message #253808] |
Wed, 29 August 2007 13:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Nicolas,
I believe these are keyed by the id.
Jason
Nicolas wrote:
> Thanks.
> Is it normal?
> dataset?
> Thanks a lot.
> Nicolas
>> Nicolas,
>> Jason
>> Nicolas wrote:
>>> Hello,
>>> plugin, can handle a property "queryTimeOut" which seems excatly what
>>> I want. But I don't find how to set it.
>>> Thanks
>>> Nicolas
Re: Query Timeout [message #253858 is a reply to message #253846] |
Wed, 29 August 2007 14:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Member |
Resolved.
Again: thanks a lot :-)
Nicolas
> Nicolas,
> Jason
> Nicolas wrote:
>> Thanks.
>> Is it normal?
>> dataset?
>> Thanks a lot.
>> Nicolas
>>> Nicolas,
>>> Jason
>>> Nicolas wrote:
>>>> Hello,
>>>> Thanks
>>>> Nicolas
FUDForum. Page generated in 0.02883 seconds
