Home » Archived » BIRT » Showing data set values in a combo box
Showing data set values in a combo box [message #253522] Mon, 27 August 2007 09:06 Go to next message
Originally posted by: ruby.boyarski.verix.com
Is there a way (even scripted) to show DB values in a combobox (HTML
SELECT)?
I plan to add script that refreshes the report with the selected value once
selected.
Ruby
Re: Showing data set values in a combo box [message #253536 is a reply to message #253522] Mon, 27 August 2007 10:15 Go to previous messageGo to next message
Ruby,
Using a dynamic dataset and then tying it to a BIRT Data Set should work.
Jason
news://news.eclipse.org/eclipse.birt wrote:
> SELECT)?
> selected.
> Ruby
Re: Showing data set values in a combo box [message #253540 is a reply to message #253536] Mon, 27 August 2007 10:18 Go to previous messageGo to next message
But the problem is not fetching the data.
I can't find a control for combo box in the palette...
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:faum71$r0h$4@build.eclipse.org...
> Ruby,
> Jason
>> SELECT)?
>> once selected.
>> Thanks,
>> Ruby
Re: Showing data set values in a combo box [message #253543 is a reply to message #253540] Mon, 27 August 2007 10:22 Go to previous messageGo to next message
Now I see that you were referring to the parameters page.
What I want to do is show a combo at the top of my report page to select a
value from a combo and then, upon user selection, show values (according to
the selection) in the lower part of the report.
Although it's like showing parameters in the same page as the report I
couldn't find a way to do so (show parameters and report on the same page)
so I thought combo with hyperlinks may be the answer... Isn't it?
"news://news.eclipse.org/eclipse.birt" <ruby.boyarski@verix.com> wrote in
message news:faumdj$toa$1@build.eclipse.org...
>> Ruby,
>> Jason
>>> Hi,
>>> SELECT)?
>>> once selected.
>>> Thanks,
>>> Ruby
Re: Showing data set values in a combo box [message #253567 is a reply to message #253543] Mon, 27 August 2007 14:39 Go to previous messageGo to next message
Ruby,
There may be better ways to do what you want, but here is an example
that uses a hidden table (OnCreate script) and a hidden data element to
add script to a report to rerun a report using a combo box.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.14"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.2.0.v20070620 Build &lt;2.2.0.v20070626-1003></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 &lt;&lt;Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<method name="beforeFactory"><![CDATA[myopts = new Array();
ii=0;]]></method>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<parameters>
<scalar-parameter name="ordern" id="60">
<property name="valueType">static</property>
<property name="dataType">integer</property>
<property name="isRequired">false</property>
<property name="controlType">text-box</property>
<property name="defaultValue">10101</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="7">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
</list-property>
<property name="queryText">select ordernumber
from orderdetails</property>
</oda-data-set>
<oda-data-set
name="orderdetails" id="22">
<structure>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<list-property name="parameters">
<structure>
<property name="name">param_1</property>
<property name="paramName">ordern</property>
<property name="nativeName"></property>
<expression name="defaultValue">10101</expression>
<property name="isOptional">false</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
</list-property>
<structure>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<property name="queryText">select *
from orderdetails
where ordernumber = ?</property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:name></design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:nullability>Unknown</design:nullability>
<design:uiHints/>
</design:attributes>
<design:inputAttributes>
<design:elementAttributes>
<design:defaultScalarValue>10101</design:defaultScalarValue >
<design:optional>false</design:optional>
<design:masksValue>false</design:masksValue>
<design:uiHints>
<design:promptStyle>TextField</design:promptStyle>
</design:uiHints>
</design:elementAttributes>
</design:inputAttributes>
</design:parameterDefinitions>
</design:DataSetParameters>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
<style name="detail" id="57">
<property name="backgroundColor">#BACAE2</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
<property name="paddingTop">0px</property>
<property name="paddingLeft">0px</property>
<property name="paddingBottom">0px</property>
<property name="paddingRight">0px</property>
</style>
<style name="headerfooter" id="58">
<property name="backgroundColor">#004080</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
</style>
<style name="groupheader" id="59">
<property name="backgroundColor">#0080FF</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="9">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<list-property name="visibility">
<structure>
<property name="format">all</property>
<expression name="valueExpr">true</expression>
</structure>
</list-property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
</list-property>
<column id="16"/>
<header>
<row id="10">
<cell id="11">
<label id="17">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="12">
<method name="onCreate"><![CDATA[myopts[ii] =
this.getRowData().getColumnValue(0);
ii++;]]></method>
<cell id="13">
<data id="18">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="14">
<cell id="15"/>
</row>
</footer>
</table>
<data id="21">
<structure>
</structure>
</list-property>
<structure>
<property name="name">Column Binding</property>
<expression name="expression">"test";</expression>
<property name="dataType">any</property>
</structure>
</list-property>
<method name="onCreate"><![CDATA[ss = "";
for( i=0; i < myopts.length; i++ ){
ss = ss + "sel1.options[" + i + "] = new Option( '" + myopts[i] + "', '"
+ myopts[i] + "');";
}]]></method>
<property name="resultSetColumn">Column Binding</property>
</data>
<text id="19">
<text-property name="content"><![CDATA[<html>
<form name='frm'>
<select name='sel'>
<option></option>
</select>
<INPUT Type="BUTTON" Value="Refresh" onClick="reloadPage(this.form)">
</form>
</html>
<script language="javascript">
function reloadPage(form) {
var sel1 = document.frm.sel;
//alert("Reload Page");
var temp = new String(location.href);
var targetURL = new String();
if(temp.indexOf("__overwrite=") != -1 ){
targetURL = temp.substring(0, temp.indexOf("&__overwrite") -1);
}else{
targetURL = temp;
targetURL += "&__overwrite=true";
targetURL += "&ordern=" + form.sel.value;
//alert( targetURL );
//window.location.href = targetURL;
document.location.replace(targetURL);
<VALUE-OF>ss;</VALUE-OF>
</script>]]></text-property>
</text>
<table id="23">
<property name="dataSet">orderdetails</property>
<structure>
<expression
</structure>
<structure>
<expression
name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<column id="52"/>
<column id="53"/>
<column id="54"/>
<column id="55"/>
<column id="56"/>
<header>
<row id="24">
<property name="style">headerfooter</property>
<cell id="25">
<label id="26">
<text-property
</label>
</cell>
<cell id="27">
<label id="28">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="29">
<label id="30">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="31">
<label id="32">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="33">
<label id="34">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="35">
<property name="style">detail</property>
<cell id="36">
<data id="37">
<property
</data>
</cell>
<cell id="38">
<data id="39">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="40">
<data id="41">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="42">
<data id="43">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="44">
<data id="45">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="46">
<cell id="47"/>
<cell id="48"/>
<cell id="49"/>
<cell id="50"/>
<cell id="51"/>
</row>
</footer>
</table>
</body>
</report>
>>> Ruby,
>>> Jason
>>>> Hi,
>>>> SELECT)?
>>>> once selected.
>>>> Thanks,
>>>> Ruby
Re: Showing data set values in a combo box [message #253637 is a reply to message #253567] Tue, 28 August 2007 02:59 Go to previous messageGo to next message
Thanks for the example! It helps a lot.
I have a problem though. When running in the "preview" or "View report as
HTML" it works well.
But, it doesn't work well when running with "View report in Web Viewer" or
when publishing it to the iServer.
The script code doesn't run (everthing else runs well) and thus the combo is
not populated. Any idea why that is and how to solve it?
Ruby
news:fav5lf$49i$1@build.eclipse.org...
> Ruby,
> There may be better ways to do what you want, but here is an example that
> uses a hidden table (OnCreate script) and a hidden data element to add
> Jason
> id="1">
> <property name="comments">Copyright (c) 2007 &lt;&lt;Your Company Name
> here>></property>
> ii=0;]]></method>
> <parameters>
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> <oda-data-source
> id="6">
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> from orderdetails
> <model:DesignValues
> <design:attributes>
> <design:uiHints/>
> <design:uiHints>
> </design:uiHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> <text-property name="content"><![CDATA[<value-of>new
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="9">
> <structure>
> </structure>
> </list-property>
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="16"/>
> <header>
> <row id="10">
> <cell id="11">
> <label id="17">
> <text-property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="12">
> ii++;]]></method>
> <cell id="13">
> <data id="18">
> <property
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="14">
> <cell id="15"/>
> </row>
> </footer>
> </table>
> <data id="21">
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> ss = ss + "sel1.options[" + i + "] = new Option( '" + myopts[i] + "', '" +
> myopts[i] + "');";
> }]]></method>
> </data>
> <text id="19">
> <form name='frm'>
> <select name='sel'>
> <option></option>
> </select>
> </form>
> </html>
> }else{
> targetURL = temp;
> </text>
> <table id="23">
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="52"/>
> <column id="53"/>
> <column id="54"/>
> <column id="55"/>
> <column id="56"/>
> <header>
> <row id="24">
> <cell id="25">
> <label id="26">
> <text-property
> </label>
> </cell>
> <cell id="27">
> <label id="28">
> <text-property
> </label>
> </cell>
> <cell id="29">
> <label id="30">
> <text-property
> </label>
> </cell>
> <cell id="31">
> <label id="32">
> <text-property
> </label>
> </cell>
> <cell id="33">
> <label id="34">
> <text-property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="35">
> <cell id="36">
> <data id="37">
> <property
> </data>
> </cell>
> <cell id="38">
> <data id="39">
> <property
> </data>
> </cell>
> <cell id="40">
> <data id="41">
> <property
> </data>
> </cell>
> <cell id="42">
> <data id="43">
> <property
> </data>
> </cell>
> <cell id="44">
> <data id="45">
> <property
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="46">
> <cell id="47"/>
> <cell id="48"/>
> <cell id="49"/>
> <cell id="50"/>
> <cell id="51"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
>> a value from a combo and then, upon user selection, show values
>> (according to the selection) in the lower part of the report.
>> page) so I thought combo with hyperlinks may be the answer... Isn't it?
>>>> Ruby,
>>>> work.
>>>> Jason
>>>>> Hi,
>>>>> SELECT)?
>>>>> once selected.
>>>>> Thanks,
>>>>> Ruby
Re: Showing data set values in a combo box [message #253710 is a reply to message #253637] Tue, 28 August 2007 13:50 Go to previous messageGo to next message
Ruby,
Try this example. I think it will suit your needs and is much simpler
as well.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.7"
id="1">
2.1.3.v20070705-1847 Build &lt;20070705-1847></property>
<property name="comments">Copyright (c) 2006 &lt;&lt;Your Company
<method name="beforeFactory"><![CDATA[scriptstring = "";]]></method>
<parameters>
<scalar-parameter name="ordernmbr" id="19">
<property name="concealValue">false</property>
<property name="allowBlank">true</property>
<property name="allowNull">true</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
id="4">
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
name="Data Set" id="5">
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
</list-property>
<property name="queryText">select distinct ordernumber
</oda-data-set>
<oda-data-set
name="orderdetails" id="6">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
<property name="paramName">ordernmbr</property>
<property name="isOptional">true</property>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
from orderdetails
<model:DesignValues
<design:attributes>
<design:uiHints/>
<design:optional>true</design:optional>
<design:uiHints>
</design:uiHints>
</oda-data-set>
</data-sets>
<styles>
<style name="detail" id="54">
<property name="fontFamily">Arial</property>
</style>
<style name="headerfooter" id="55">
</style>
<style name="groupheader" id="56">
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<table id="7">
<structure>
</structure>
</list-property>
<structure>
<expression
</structure>
</list-property>
<column id="16"/>
<header>
<row id="8">
<cell id="9">
<label id="10">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="11">
<method name="onCreate"><![CDATA[var colval =
scriptstring= scriptstring + "<option value='" + colval +
"'>"+colval+"</option>";]]></method>
<cell id="12">
<data id="13">
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="14">
<cell id="15"/>
</row>
</footer>
</table>
<text id="17">
<form name='frm' action="">
function rp(form) {
var sel1 = form.ordernmbr;
var xyz = -1;
xyz=temp.indexOf("__overwrite=")
if( xyz != -1 ){
//alert( xyz );
targetURL = temp.substring(0, xyz-1);
//alert(temp.substring(0, xyz-1));
}else{
targetURL = temp;
targetURL += "&ordernmbr=" + form.ordernmbr.value;
</script>
<select name='ordernmbr'>
<VALUE-OF format="HTML">scriptstring;</VALUE-OF>
</select>
<INPUT Type="BUTTON" name="mybutton" Value="Refresh"
onClick='reloadPage(this.form)'></INPUT>
</form>]]></text-property>
</text>
<table id="20">
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
</list-property>
<column id="49"/>
<column id="50"/>
<column id="51"/>
<column id="52"/>
<column id="53"/>
<header>
<row id="21">
<cell id="22">
<label id="23">
<text-property
</label>
</cell>
<cell id="24">
<label id="25">
<text-property
</label>
</cell>
<cell id="26">
<label id="27">
<text-property
</label>
</cell>
<cell id="28">
<label id="29">
<text-property
</label>
</cell>
<cell id="30">
<label id="31">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="32">
<cell id="33">
<data id="34">
<property
</data>
</cell>
<cell id="35">
<data id="36">
<property
</data>
</cell>
<cell id="37">
<data id="38">
<property
</data>
</cell>
<cell id="39">
<data id="40">
<property
</data>
</cell>
<cell id="41">
<data id="42">
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="43">
<cell id="44"/>
<cell id="45"/>
<cell id="46"/>
<cell id="47"/>
<cell id="48"/>
</row>
</footer>
</table>
</body>
</report>
> Cheers,
> Ruby
>> Ruby,
>> Jason
>> <?xml version="1.0" encoding="UTF-8"?>
>> id="1">
>> here>></property>
>> ii=0;]]></method>
>> <parameters>
>> </structure>
>> </scalar-parameter>
>> </parameters>
>> <data-sources>
>> <oda-data-source
>> id="6">
>> <property
>> </oda-data-source>
>> </data-sources>
>> <data-sets>
>> <oda-data-set
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </oda-data-set>
>> <oda-data-set
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> from orderdetails
>> <model:DesignValues
>> <design:attributes>
>> <design:uiHints/>
>> <design:uiHints>
>> </design:uiHints>
>> <design:attributes>
>> <design:usageHints>
>> <design:attributes>
>> <design:usageHints>
>> <design:attributes>
>> <design:usageHints>
>> <design:attributes>
>> <design:usageHints>
>> <design:attributes>
>> <design:usageHints>
>> </oda-data-set>
>> </data-sets>
>> <styles>
>> </style>
>> </style>
>> </style>
>> </style>
>> </style>
>> </styles>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <table id="9">
>> <structure>
>> </structure>
>> </list-property>
>> <structure>
>> <expression
>> </structure>
>> </list-property>
>> <column id="16"/>
>> <header>
>> <row id="10">
>> <cell id="11">
>> <label id="17">
>> <text-property
>> </label>
>> </cell>
>> </row>
>> </header>
>> <detail>
>> <row id="12">
>> ii++;]]></method>
>> <cell id="13">
>> <data id="18">
>> <property
>> </data>
>> </cell>
>> </row>
>> </detail>
>> <footer>
>> <row id="14">
>> <cell id="15"/>
>> </row>
>> </footer>
>> </table>
>> <data id="21">
>> <structure>
>> </structure>
>> </list-property>
>> <structure>
>> </structure>
>> </list-property>
>> myopts[i] + "');";
>> }]]></method>
>> </data>
>> <text id="19">
>> <form name='frm'>
>> <select name='sel'>
>> <option></option>
>> </select>
>> </form>
>> </html>
>> }else{
>> targetURL = temp;
>> </text>
>> <table id="23">
>> <structure>
>> <expression
>> </structure>
>> <structure>
>> <expression
>> </structure>
>> <structure>
>> <expression
>> </structure>
>> <structure>
>> <expression
>> </structure>
>> <structure>
>> <expression
>> </structure>
>> </list-property>
>> <column id="52"/>
>> <column id="53"/>
>> <column id="54"/>
>> <column id="55"/>
>> <column id="56"/>
>> <header>
>> <row id="24">
>> <cell id="25">
>> <label id="26">
>> <text-property
>> </label>
>> </cell>
>> <cell id="27">
>> <label id="28">
>> <text-property
>> </label>
>> </cell>
>> <cell id="29">
>> <label id="30">
>> <text-property
>> </label>
>> </cell>
>> <cell id="31">
>> <label id="32">
>> <text-property
>> </label>
>> </cell>
>> <cell id="33">
>> <label id="34">
>> <text-property
Re: Showing data set values in a combo box [message #254331 is a reply to message #253710] Tue, 04 September 2007 04:41 Go to previous messageGo to next message
Still, when running the report the "Reload" button doesn't work. It seems
not to recognize the "reloadPage" method.
The combo is populated though...
Any idea?
Ruby
news:fb1n5s$u6d$1@build.eclipse.org...
> Ruby,
> Try this example. I think it will suit your needs and is much simpler as
> well.
> Jason
> id="1">
> <property name="comments">Copyright (c) 2006 &lt;&lt;Your Company Name
> here>></property>
> <parameters>
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> <oda-data-source
> id="4">
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> from orderdetails
> <model:DesignValues
> <design:attributes>
> <design:uiHints/>
> <design:uiHints>
> </design:uiHints>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="7">
> <structure>
> </structure>
> </list-property>
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="16"/>
> <header>
> <row id="8">
> <cell id="9">
> <label id="10">
> <text-property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="11">
> <cell id="12">
> <data id="13">
> <property
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="14">
> <cell id="15"/>
> </row>
> </footer>
> </table>
> <text id="17">
> function rp(form) {
> var xyz = -1;
> if( xyz != -1 ){
> //alert( xyz );
> }else{
> targetURL = temp;
> </script>
> </select>
> </text>
> <table id="20">
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="49"/>
> <column id="50"/>
> <column id="51"/>
> <column id="52"/>
> <column id="53"/>
> <header>
> <row id="21">
> <cell id="22">
> <label id="23">
> <text-property
> </label>
> </cell>
> <cell id="24">
> <label id="25">
> <text-property
> </label>
> </cell>
> <cell id="26">
> <label id="27">
> <text-property
> </label>
> </cell>
> <cell id="28">
> <label id="29">
> <text-property
> </label>
> </cell>
> <cell id="30">
> <label id="31">
> <text-property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="32">
> <cell id="33">
> <data id="34">
> <property
> </data>
> </cell>
> <cell id="35">
> <data id="36">
> <property
> </data>
> </cell>
> <cell id="37">
> <data id="38">
> <property
> </data>
> </cell>
> <cell id="39">
> <data id="40">
> <property
> </data>
> </cell>
> <cell id="41">
> <data id="42">
> <property
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="43">
> <cell id="44"/>
> <cell id="45"/>
> <cell id="46"/>
> <cell id="47"/>
> <cell id="48"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
>> or when publishing it to the iServer.
>> is not populated. Any idea why that is and how to solve it?
>> Cheers,
>> Ruby
>>> Ruby,
>>> Jason
>>> id="1">
>>> ii=0;]]></method>
>>> <parameters>
>>> </structure>
>>> </scalar-parameter>
>>> </parameters>
>>> <data-sources>
>>> <oda-data-source
>>> id="6">
>>> <property
>>> <property
>>> </oda-data-source>
>>> </data-sources>
>>> <data-sets>
>>> <oda-data-set
>>> <structure>
>>> </structure>
>>> </list-property>
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> </oda-data-set>
>>> <oda-data-set
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> <property
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> <property
>>> </structure>
>>> </list-property>
>>> from orderdetails
>>> <model:DesignValues
>>> <design:attributes>
>>> <design:uiHints/>
>>> <design:uiHints>
>>> </design:uiHints>
>>> <design:attributes>
>>> <design:usageHints>
>>> <design:attributes>
>>> <design:usageHints>
>>> <design:attributes>
>>> <design:usageHints>
>>> <design:attributes>
>>> <design:usageHints>
>>> <design:attributes>
>>> <design:usageHints>
>>> </oda-data-set>
>>> </data-sets>
>>> <styles>
>>> </style>
>>> </style>
>>> </style>
>>> </style>
>>> </style>
>>> </styles>
>>> <page-setup>
>>> <page-footer>
>>> <text id="3">
>>> </text>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <table id="9">
>>> <structure>
>>> </structure>
>>> </list-property>
>>> <structure>
>>> <expression
>>> </structure>
>>> </list-property>
>>> <column id="16"/>
>>> <header>
>>> <row id="10">
>>> <cell id="11">
>>> <label id="17">
>>> <text-property
>>> </label>
>>> </cell>
>>> </row>
>>> </header>
>>> <detail>
>>> <row id="12">
>>> ii++;]]></method>
>>> <cell id="13">
>>> <data id="18">
>>> <property
>>> </data>
>>> </cell>
>>> </row>
>>> </detail>
>>> <footer>
>>> <row id="14">
>>> <cell id="15"/>
>>> </row>
>>> </footer>
>>> </table>
>>> <data id="21">
>>> <structure>
>>> </structure>
>>> </list-property>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> }]]></method>
>>> </data>
>>> <text id="19">
>>> <form name='frm'>
>>> <select name='sel'>
>>> <option></option>
>>> </select>
>>> </form>
>>> </html>
>>> }else{
>>> targetURL = temp;
>>> </text>
>>> <table id="23">
>>> <structure>
>>> <expression
>>> <property name="dataType">integer</property><
Re: Showing data set values in a combo box [message #254363 is a reply to message #253710] Tue, 04 September 2007 06:36 Go to previous messageGo to next message
Any idea?
Ruby
> Ruby,
> well.
> Jason
> id="1">
> here>></property>
> <parameters>
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> <oda-data-source
> id="4">
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> from orderdetails
> <model:DesignValues
> <design:attributes>
> <design:uiHints/>
> <design:uiHints>
> </design:uiHints>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="7">
> <structure>
> </structure>
> </list-property>
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="16"/>
> <header>
> <row id="8">
> <cell id="9">
> <label id="10">
> <text-property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="11">
> <cell id="12">
> <data id="13">
> <property
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="14">
> <cell id="15"/>
> </row>
> </footer>
> </table>
> <text id="17">
> function rp(form) {
> var xyz = -1;
> if( xyz != -1 ){
> //alert( xyz );
> }else{
> targetURL = temp;
> </script>
> </select>
> </text>
> <table id="20">
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="49"/>
> <column id="50"/>
> <column id="51"/>
> <column id="52"/>
> <column id="53"/>
> <header>
> <row id="21">
> <cell id="22">
> <label id="23">
> <text-property
> </label>
> </cell>
> <cell id="24">
> <label id="25">
> <text-property
> </label>
> </cell>
> <cell id="26">
> <label id="27">
> <text-property
> </label>
> </cell>
> <cell id="28">
> <label id="29">
> <text-property
> </label>
> </cell>
> <cell id="30">
> <label id="31">
> <text-property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="32">
> <cell id="33">
> <data id="34">
> <property
> </data>
> </cell>
> <cell id="35">
> <data id="36">
> <property
> </data>
> </cell>
> <cell id="37">
> <data id="38">
> <property
> </data>
> </cell>
> <cell id="39">
> <data id="40">
> <property
> </data>
> </cell>
> <cell id="41">
> <data id="42">
> <property
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="43">
> <cell id="44"/>
> <cell id="45"/>
> <cell id="46"/>
> <cell id="47"/>
> <cell id="48"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
>> Cheers,
>> Ruby
>>> Ruby,
>>> Jason
>>> id="1">
>>> ii=0;]]></method>
>>> <parameters>
>>> </structure>
>>> </scalar-parameter>
>>> </parameters>
>>> <data-sources>
>>> <oda-data-source
>>> id="6">
>>> <property
>>> <property
>>> </oda-data-source>
>>> </data-sources>
>>> <data-sets>
>>> <oda-data-set
>>> <structure>
>>> </structure>
>>> </list-property>
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> </oda-data-set>
>>> <oda-data-set
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> <property
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> <property
>>> </structure>
>>> </list-property>
>>> from orderdetails
>>> <model:DesignValues
>>> <design:attributes>
>>> <design:uiHints/>
>>> <design:uiHints>
>>> </design:uiHints>
>>> <design:attributes>
>>> <design:usageHints>
>>> <design:attributes>
>>> <design:usageHints>
>>> <design:attributes>
>>> <design:usageHints>
>>> <design:attributes>
>>> <design:usageHints>
>>> <design:attributes>
>>> <design:usageHints>
>>> </oda-data-set>
>>> </data-sets>
>>> <styles>
>>> </style>
>>> </style>
>>> </style>
>>> </style>
>>> </style>
>>> </styles>
>>> <page-setup>
>>> <page-footer>
>>> <text id="3">
>>> </text>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <table id="9">
>>> <structure>
>>> </structure>
>>> </list-property>
>>> <structure>
>>> <expression
>>> </structure>
>>> </list-property>
>>> <column id="16"/>
>>> <header>
>>> <row id="10">
>>> <cell id="11">
>>> <label id="17">
>>> <text-property
>>> </label>
>>> </cell>
>>> </row>
>>> </header>
>>> <detail>
>>> <row id="12">
>>> ii++;]]></method>
>>> <cell id="13">
>>> <data id="18">
>>> <property
>>> </data>
>>> </cell>
>>> </row>
>>> </detail>
>>> <footer>
>>> <row id="14">
>>> <cell id="15"/>
>>> </row>
>>> </footer>
>>> </table>
>>> <data id="21">
>>> <structure>
>>> </structure>
>>> </list-property>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> }]]></method>
>>> </data>
>>> <text id="19">
>>> <form name='frm'>
>>> <select name='sel'>
>>> <option></option>
>>> </select>
>>> </form>
>>> </html>
>>> }else{
>>> targetURL = temp;
>>> </text>
>>> <table id="23">
>>> <structure>
>>> <expression
Re: Showing data set values in a combo box - solved [message #254377 is a reply to message #254363] Tue, 04 September 2007 07:39 Go to previous message
I solved it by changing the code to be as follows (if you have comments -
you are welcomed).
Seems that <script> tag doesn't work for some reason under the "Web viewer"
and "iPortal"...
Thanks very much for your help.
Ruby
<span id='ttt' style='visibility:hidden'>
var xyz = -1;
xyz=temp.indexOf("__overwrite=");
if( xyz != -1 ){
}else{
targetURL = temp;
</span>
</select>
onClick='eval(document.all.ttt.innerText);reloadPage(this.fo rm)' ></INPUT>
</form>
message news:fbjcdm$121$1@build.eclipse.org...
> Any idea?
> Ruby
>> Ruby,
>> well.
>> Jason
>> id="1">
>> <parameters>
>> </structure>
>> </scalar-parameter>
>> </parameters>
>> <data-sources>
>> <oda-data-source
>> id="4">
>> <property
>> <property
>> </oda-data-source>
>> </data-sources>
>> <data-sets>
>> <oda-data-set
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </oda-data-set>
>> <oda-data-set
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> <property
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> <property
>> </structure>
>> </list-property>
>> from orderdetails
>> <model:DesignValues
>> <design:attributes>
>> <design:uiHints/>
>> <design:uiHints>
>> </design:uiHints>
>> </oda-data-set>
>> </data-sets>
>> <styles>
>> </style>
>> </style>
>> </style>
>> </styles>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <table id="7">
>> <structure>
>> </structure>
>> </list-property>
>> <structure>
>> <expression
>> </structure>
>> </list-property>
>> <column id="16"/>
>> <header>
>> <row id="8">
>> <cell id="9">
>> <label id="10">
>> <text-property
>> </label>
>> </cell>
>> </row>
>> </header>
>> <detail>
>> <row id="11">
>> <cell id="12">
>> <data id="13">
>> <property
>> </data>
>> </cell>
>> </row>
>> </detail>
>> <footer>
>> <row id="14">
>> <cell id="15"/>
>> </row>
>> </footer>
>> </table>
>> <text id="17">
>> function rp(form) {
>> var xyz = -1;
>> if( xyz != -1 ){
>> //alert( xyz );
>> }else{
>> targetURL = temp;
>> </script>
>> </select>
>> </text>
>> <table id="20">
>> <structure>
>> <expression
>> </structure>
>> <structure>
>> <expression
>> </structure>
>> <structure>
>> <expression
>> </structure>
>> <structure>
>> <expression
>> </structure>
>> <structure>
>> <expression
>> </structure>
>> </list-property>
>> <column id="49"/>
>> <column id="50"/>
>> <column id="51"/>
>> <column id="52"/>
>> <column id="53"/>
>> <header>
>> <row id="21">
>> <cell id="22">
>> <label id="23">
>> <text-property
>> </label>
>> </cell>
>> <cell id="24">
>> <label id="25">
>> <text-property
>> </label>
>> </cell>
>> <cell id="26">
>> <label id="27">
>> <text-property
>> </label>
>> </cell>
>> <cell id="28">
>> <label id="29">
>> <text-property
>> </label>
>> </cell>
>> <cell id="30">
>> <label id="31">
>> <text-property
>> </label>
>> </cell>
>> </row>
>> </header>
>> <detail>
>> <row id="32">
>> <cell id="33">
>> <data id="34">
>> <property
>> </data>
>> </cell>
>> <cell id="35">
>> <data id="36">
>> <property
>> </data>
>> </cell>
>> <cell id="37">
>> <data id="38">
>> <property
>> </data>
>> </cell>
>> <cell id="39">
>> <data id="40">
>> <property
>> </data>
>> </cell>
>> <cell id="41">
>> <data id="42">
>> <property
>> </data>
>> </cell>
>> </row>
>> </detail>
>> <footer>
>> <row id="43">
>> <cell id="44"/>
>> <cell id="45"/>
>> <cell id="46"/>
>> <cell id="47"/>
>> <cell id="48"/>
>> </row>
>> </footer>
>> </table>
>> </body>
>> </report>
>>> as HTML" it works well.
>>> combo is not populated. Any idea why that is and how to solve it?
>>> Cheers,
>>> Ruby
>>>> Ruby,
>>>> Jason
>>>> version="3.2.14" id="1">
>>>> ii=0;]]></method>
>>>> <parameters>
>>>> </structure>
>>>> </scalar-parameter>
>>>> </parameters>
>>>> <data-sources>
>>>> <oda-data-source
>>>> id="6">
>>>> <property
>>>> <property
>>>> </oda-data-source>
>>>> </data-sources>
>>>> <data-sets>
>>>> <oda-data-set
>>>> <structure>
>>>> </structure>
>>>> </list-property>
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> </list-property>
>>>> </oda-data-set>
>>>> <oda-data-set
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> <property
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> <property
>>>> </structure>
>>>> </list-property>
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> </list-property>
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> <property
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> <property
>>>> </structure>
>>>> </list-property>
>>>> from orderdetails
>>>> <model:DesignValues
>>>> <design:attributes>
>>>> <design:uiHints/>
>>>> <design:uiHints>
>>>> </design:uiHints>
>>>> <design:attributes>
>>>> <design:usageHints>
>>>> <design:attributes>
>>>> <design:usageHints>
>>>> <design:attributes>
>>>> <design:usageHints>
>>>> <design:attributes>
>>>> <design:usageHints>
>>>> <design:attributes>
>>>> <design:usageHints>
>>>> </oda-data-set>
>>>> </data-sets>
>>>> <styles>
>>>> </style>
>>>> </style>
>>>> </style>
>>>> </style>
>>>> </style>
>>>> </styles>
>>>> <page-setup>
>>>> <page-footer>
>>>> <text id="3">
>>>> <text-property
>>>> </text>
>>>> </page-footer>
>>>> </page-setup>
>>>> <body>
>>>> <table id="9">
>>>> <structure>
>>>> </structure>
>>>> </list-property>
>>>> <structure>
>>>> <expression
>>>> </structure>
>>>> </list-property>
>>>> <column id="16"/>
>>>> <header>
>>>> <row id="10">
>>>> <cell id="11">
>>>> <label id="17">
>>>> <text-property
>>>> </label>
>>>> </cell>
>>>> </row>
>>>> </header>
>>>> <detail>
>>>> <row id="12">
>>>> ii++;]
Previous Topic:BIRT CHART spec Drill Down functionality.
Next Topic:Empty Column in Excel Output
Current Time: Fri Oct 17 23:30:41 EDT 2025
Powered by FUDForum. Page generated in 0.10616 seconds
