Home » Eclipse Projects » GEF » Shouldn't getDragTracker() return always the same instance of a DragTracker?
Shouldn't getDragTracker() return always the same instance of a DragTracker? [message #24963] Mon, 07 October 2002 10:48 Go to next message
I am a bit concerned by the implementation of the getDragTracker() method in
class org.eclipse.gef.examples.logicdesigner.edit.LogicDiagramEdit Part of
the Logical Diagram Editor example (latest version, i.e., 20020821).
Indeed, this method implementation:
public DragTracker getDragTracker(Request req){
return new MarqueeDragTracker();
returns a new object each time it is called.... and it is called each time a
drag selection is began.
Shouldn't it be better to use a singleton to create once a
MarqueeDragTracker() and always return this instance?
I made this modification to my code which run fine, except that it does no
longuer perform so many object creations...
Is this okay from GEF interfaces / internal flow of calls, or am I taking a
risk?
Alex
Re: Shouldn't getDragTracker() return always the same instance of a DragTracker? [message #25120 is a reply to message #24963] Mon, 07 October 2002 14:24 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
I don't see any reason to cache the tool. The MouseEvent that was the cause
of the marquee tool being activated is also a new Object. There are
probably several other new objects created then too, and none of them are
expensive.
"Alexandre Vermeerbergen" <ave@ds-fr.com> wrote in message
news:ans5g6$mer$1@rogue.oti.com...
> Hello,
in
a
a
> risk?
> Best regards,
> Alex
Re: Shouldn't getDragTracker() return always the same instance of a DragTracker? [message #25486 is a reply to message #25120] Tue, 08 October 2002 08:53 Go to previous message
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:ansi5p$vkr$1@rogue.oti.com...
cause
> expensive.
Alright, so you mean my optimization is not false, but it is of little
value, right?
At least if it's not breaking anything and saves a little bit of garbage
collector's work...
So I can do it anyway, I guess.
Alex.
Previous Topic:Hello Gef #1 : a first tutorial example (comments welcome)
Next Topic:Create a Diamond Class using Polygon Class in GEF
Current Time: Mon Nov 03 04:49:51 EST 2025
Powered by FUDForum. Page generated in 0.08386 seconds
