| birt 2.2 fails to locate java classes in importPackage script statements [message #253057] |
Mon, 20 August 2007 17:22   |
Eclipse User  |
We use the BIRT Runtime API, and after we upgraded from BIRT 2.1.1 to 2.2
the scripting engine now fails to locate java classes referenced in the
importPackage of a report script.  The classes that we use in the script are
part of the same java application that uses the BIRT Runtime API.
The exact error message is:
Aug 20, 2007 11:27:55 AM
 org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor handleJS
WARNING: A BIRT exception occurred: Error evaluating Javascript expression.
Script engine error: ReferenceError: "IeBirtFilter" is not defined.
(DataSource[DSS].__bm_beforeOpen#9)
 Script source: DataSource[DSS].__bm_beforeOpen, line: 1, text:
__bm_beforeOpen().
Everything worked fine under Birt 2.1.1  We were getting the errors under
Eclipse 3.2.  I switched to Eclipse 3.3 but still received the same errors.
Any ideas what can be causing this error?  I've tried everything I can think
of.  Thank you.
| birt 2.2 fails to locate java classes in the ODA driver when in RCP Designer [message #254072 is a reply to message #253821] |
Fri, 31 August 2007 06:49   |
Eclipse User  |
Originally posted by: firstname.lastname.napa.fi
On Wed, 29 Aug 2007 10:48:42 +0300, Antti Karanta  =
<firstname.lastname@napa.fi> wrote:
>> clf - You were right.  I had to add code to set the appclassloader of=
>> the report engine via  EngineConstants.APPCONTEXT_CLASSLOADER_KEY.  I=
n  =
>> my case, the exact code was:
>>  contextMap.put(EngineConstants.APPCONTEXT_CLASSLOADER_KEY,Re portEngin=
e.class.getClassLoader());
   I have now confirmed that the javascript snippets are able to access =
the  =
classes in the driver ok when APPCONTEXT_CLASSLOADER_KEY is set as above=
   However, this only works when embedding BIRT. I haven't found a way t=
o  =
make it work with BIRT runtime's genReport.bat nor in BIRT RCP Report  =
Designer's preview. I'd need to have at least the latter one working as =
it  =
will be very inconvenient to design reports and only be able to preview =
them correctly from the embedding app.
   BTW, I need to access the classes via the same classloader that the  =
driver uses. This is because I am accessing a native library and having =
multiple versions of the classes by separate classloaders within the sam=
e  =
process would lead into problems. To put it another way, I need to acces=
s  =
the same objects (the one I need is available as a singleton) that the  =
driver is accessing.
   Should I reopen https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D18627=
2 ?  =
Or is there a way to make this work? Is there something I can do in the =
plugin code?
      -Antti-
FUDForum. Page generated in 0.07990 seconds
