Home » Eclipse Projects » Eclipse Platform » Syntax highlighting / Code Completion in JSPs (3.0 RC2)
Syntax highlighting / Code Completion in JSPs (3.0 RC2) [message #252969] Wed, 16 June 2004 02:44 Go to next message
Originally posted by: eclipselist.juergenebert.de
Hi there,
I downloaded Eclipse 3.0 RC2 to give it a try after years of using
netbeans ;-). The feature I am most interested in is the JSP sytax
highlighting and code completion which I thought was advertised as being
included in 3.0. So I set up a project and imported some JSPs but they
were treated as plain text.
Do I need to download a plugin (like SolarEclipse) or is there a hidden
switch somewhere?
Juergen
Re: Syntax highlighting / Code Completion in JSPs (3.0 RC2) [message #253160 is a reply to message #252969] Wed, 16 June 2004 10:32 Go to previous messageGo to next message
Originally posted by: rsk.email.arizona.edu
Juergen,
You will need a plugin. Lomboz is an open source one and MyEclipse is a
commercial one (although only $30/year).
M7 is another commercial one, but much more $$$ ($399->$699 I believe).
Jürgen Ebert wrote:
> Hi there,
> switch somewhere?
> Juergen
Re: Syntax highlighting / Code Completion in JSPs (3.0 RC2) [message #253168 is a reply to message #253160] Wed, 16 June 2004 10:31 Go to previous messageGo to next message
but Lomboz doesn't work properly, isn't it?
I use M8 and code completion doesn't work. What am I doing wrong?
Jens :-)
Riyad Kalla wrote:
> Juergen,
> Jürgen Ebert wrote:
> > Hi there,
> > switch somewhere?
> > Regards,
> > Juergen
Re: Syntax highlighting / Code Completion in JSPs (3.0 RC2) [message #253229 is a reply to message #253160] Wed, 16 June 2004 12:00 Go to previous message
Thanks for the response, Riyad,
what is the Eclipse project plan about then? There I found "Theme:
Extended Java Family" with two commited items. And the first item
contains "it should be possible to use Java code assist on the Java
passages".
Does this mean that the Eclipse platform now contains the API but does
itself not make use of it? Just better support for plugin developers? Or
should Eclipse be able to edit JSP pages right out of the box?
I downloaded Lomboz but installation does not work for me.
Juergen
Riyad Kalla wrote:
> Juergen,
> Jürgen Ebert wrote:
>> Hi there,
>> being included in 3.0. So I set up a project and imported some JSPs
>> but they were treated as plain text.
>> hidden switch somewhere?
>> Regards,
>> Juergen
Previous Topic:HELP!!! Disable menu item
Next Topic:How to find a plugin's install directory now that getDescriptor is deprecated?
Current Time: Tue Apr 29 01:00:27 EDT 2025
Powered by FUDForum. Page generated in 0.30640 seconds
