Re: -debug to file in RC1 [message #252802 is a reply to message #252782] |
Tue, 15 June 2004 17:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Try adding -consoleLog See if that helps.
Lester Caine wrote:
> I've been asked to run
> eclipse -debug xxx/.options > tracelog.txt
> in a DOS box on W2k in order to debug a problem with a plugin, but while
> it works in M7 ( I am informed ) when run in RC1, a second DOS window
> opens and the debug information scrolls past without going to the .txt
> file.
> How do I do this now in RC1?
Thanks, Rich Kulp
Re: -debug to file in RC1 [message #253248 is a reply to message #253092] |
Wed, 16 June 2004 16:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: dorian.birsan.net
"Lester Caine" <lester@lsces.co.uk> wrote in message
news:capene$51d$1@eclipse.org...
> Lester Caine wrote:
> > No change - still does not give me the debug log to a file.
> > Just checked back to M8 and have the same problem.
> >>> while it works in M7 ( I am informed ) when run in RC1, a second DOS
> >>> window opens and the debug information scrolls past without going to
> >>> the .txt file.
> Come on guys and galls - is there no way of getting the debug
> information into a file that I can forward to allow the developer to
> sort out remaining Eclipse3 porting problems?
how about using the standard output/error redirection?
for example: eclipse.exe -debug >out.txt
> Lester Caine
> L.S.Caine Electronic Services
Re: -debug to file in RC1 [message #253409 is a reply to message #253260] |
Wed, 16 June 2004 20:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
news:capsif$omf$1@eclipse.org...
> Read the notes :)
d'oh! bad eyes :-)
> That is EXACTLY what I am doing, but apparently from version M8 onwards,
> out.txt is populated with a samll amount of java data, while all the
> debug information which I need scrolls away in the SECOND DOS window
> which was opened by the Java startup !
Try bypassing eclipse.exe. Running from the eclipse directory, you can try:
java -cp startup.jar org.eclipse.core.launcher.Main -debug >out.txt
> Lester Caine
FUDForum. Page generated in 0.03919 seconds
