Can't display chart in birt viewer suse linux ,websphere 5.1 [message #252736] |
Thu, 16 August 2007 13:50 |
Originally posted by: shreya_1107.hotmail.com
Birt report viewer is not generating chart report in suse linux
,websphere 5.1 environment, database is db2. It generates only the table,
I am able to see the table but not pie and bar charts. But the same
folder/files are working fine in windows tomcat env. I have followed the
document: http://wiki.eclipse.org/Birt_WebSphere_Deployment
Initally i got the following errors and to fix this, I re-started the
websphere and copied all org.eclipse.chart.*.jar files to WEB-INF/lib/:
faultCode: ReportEngineService.runReport( )
faultSubcode:
faultString: Error happended while running the report
faultActor:
faultNode:
faultDetail:
{http://xml.apache.org/axis/}stackTrace:Error happended while
running the report
org.eclipse.birt.report.service.ReportEngineService.runRepor t(Unknown
Source)
org.eclipse.birt.report.service.BirtViewerReportService.runR eport(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.BirtRunReportA ctionHandler.__execute(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.BirtGetPageAct ionHandler.__checkDocumentExists(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.prepareParameters(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.__execute(Unknown
Source)
Source)
org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProcessor.__executeAction(Unknown
Source)
org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.executeAction(Unknown
Source)
org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.handleGetPage(Unknown
Source)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java(Compiled
Code))
Code))
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java(Compiled
Code))
at java.lang.reflect.Method.invoke(Method.java(Compiled Code))
org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(Unknown
Source)
org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(Unknown
Source)
Code))
Code))
Code))
org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397)
org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186)
org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323)
org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.plugins.CompatibilityActivator.sta rt() of bundle
org.eclipse.core.runtime.compatibility.
eclipse.buildId=unknown
java.fullversion=J2RE 1.4.1 IBM build cxia321411-20031011 (JIT enabled:
jitc)
BootLoader constants: OS=linux, ARCH=x86, WS=motif, NL=en_US
Command-line arguments: -clean
!ENTRY org.eclipse.osgi 4 0 2007-08-09 11:57:25.730
!MESSAGE Bundle org.junit not found.
!ENTRY org.eclipse.osgi 4 0 2007-08-09 11:57:29.305
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.core.runtime.compatibility (32).
!STACK 0
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1014)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:86)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:409)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:339)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:391)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:352)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java(Compiled Code))
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:276)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
org.eclipse.core.internal.runtime.CompatibilityHelper.getPlu ginDescriptor(CompatibilityHelper.java:63)
org.eclipse.core.runtime.Plugin.initializeDescriptor(Plugin. java:706)
at org.eclipse.core.runtime.Plugin.start(Plugin.java:692)
org.eclipse.birt.core.plugin.BIRTPlugin.start(BIRTPlugin.jav a:23)
org.eclipse.birt.report.engine.plugin.EnginePlugin.start(Eng inePlugin.java:22)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:995)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:989)
thanks in advance!
Re: Can't display chart in birt viewer suse linux ,websphere 5.1 [message #252885 is a reply to message #252736] |
Fri, 17 August 2007 14:22 |
David Michonneau Messages: 1145 Registered: July 2009 |
Please try with BIRT 2.1.3 or BIRT 2.2, if you use an earlier version,
without copying the jars. It should work out of the box, copying jars from
one location to another is likely to break it.
David
"shreya" <shreya_1107@hotmail.com> wrote in message
news:93df8bbe7cbf36db85ff3b6eb686f982$1@www.eclipse.org...
> Birt report viewer is not generating chart report in suse linux ,websphere
> 5.1 environment, database is db2. It generates only the table, I am able
> to see the table but not pie and bar charts. But the same folder/files are
> working fine in windows tomcat env. I have followed the document:
> faultSubcode:
> faultActor:
> faultNode:
> faultDetail:
> running the report
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Code))
> at
> Code))
> at
> Code))
> at
> Source)
> at
> Source)
> at
> Code))
> at
> Code))
> at
> Code))
> at
> at
> at
> jitc)
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> thanks in advance!
FUDForum. Page generated in 0.03258 seconds
