problem with MessageDialog.openInformation [message #252401] |
Tue, 25 March 2008 22:28 |
Originally posted by: hisastro.gmail.com
hi.
when I write this in the Run method :
MessageDialog.openInformation (......... )
it does not work :(
i have also written this for import :
import org.eclipse.jface.dialogs.*;
what is the problem ?
thank you in advance
Re: problem with MessageDialog.openInformation [message #252423 is a reply to message #252416] |
Wed, 26 March 2008 01:37 |
thank you for reply.
when I write the "MessageDialog" and I press the "." the editor does not
have any openInformation command to propose .. and if I write it by hand
MessageDialog.openInformation(workbenchwindow.getShell(),"something ","something");
it says that it the method"openInformation" is undefined for the type
MessageDialog.
FUDForum. Page generated in 0.07592 seconds
