Home » Language IDEs » Java Development Tools (JDT) » Debug: Accessing function variables from inner classes not possible
Debug: Accessing function variables from inner classes not possible [message #252212] Tue, 25 March 2008 15:39 Go to next message
Originally posted by: higherfalling.googlemail.com
is it possible to access / inspect member variables of a function in an
anonymous inner class like below in following code example? When i put a
breakpoint to the actionPerformed method i cannot access the variables
from the constructor. Is this a bug or some configuration work?
Thanks for your advice
Frank
public class SwingTest {
SwingTest(){
JFrame frame = new JFrame("HelloWorldSwing");
final JLabel label = new JLabel("Some text");
JButton button = new JButton("Click");
final JTextField textField = new JTextField();
button.addActionListener(new ActionListener(){
public void actionPerformed(ActionEvent e) {
label.setText("You entered: "+ textField.getText());
frame.getContentPane().setLayout( new GridLayout());
frame.getContentPane().add(textField);
frame.getContentPane().add(button);
frame.getContentPane().add(label);
frame.pack();
frame.setVisible(true);
SwingTest swingTest = new SwingTest();
Re: Debug: Accessing function variables from inner classes not possible [message #252216 is a reply to message #252212] Tue, 25 March 2008 15:41 Go to previous messageGo to next message
I forgot: I use eclipse 3.3.2
Re: Debug: Accessing function variables from inner classes not possible [message #252260 is a reply to message #252212] Wed, 26 March 2008 09:32 Go to previous message
Frank wrote:
> Hello,
This can't work the way you want. The problem is that the c'tor
variables are out of scope at the time when actionPerformed() is called
(it is called by the Swing event thread in response to an event on the
JButton). In order to make them in scope in actionPerformed() you'd have
to refer to them in that method (which will only work for the ones that
are declared final, by the way).
Hope this helps,
Eric
> SwingTest(){
> textField.getText()); }
> }); frame.getContentPane().setLayout( new GridLayout());
> frame.pack();
> public static void main(String[] args) {
Previous Topic:External Tool Builder isn't executed during manual build and auto build
Next Topic:How to make Source->Generate getters and setters use PropertyChange
Current Time: Wed Oct 22 08:39:56 EDT 2025
Powered by FUDForum. Page generated in 0.04094 seconds
