Home » Eclipse Projects » DSDP - Target Management » Custom port for SSH in Remote Systems
Custom port for SSH in Remote Systems [message #24790] Sun, 13 July 2008 14:10 Go to next message
Originally posted by: mariusz.medikoo.com
Is there any way to change port of SSH connection?
I'm working with server that has SSH not on 22 port - and it looks that I
cannot use remote systems with that :/
Re: Custom port for SSH in Remote Systems [message #24824 is a reply to message #24790] Thu, 17 July 2008 09:31 Go to previous message
You can:
1.) Create normal SSH Only connection with the wizard
2.) Select the "Sftp Files" subsystem, right-click > Properties
3.) On Subsystem Properties, change the port number.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> I cannot use remote systems with that :/
Re: Custom port for SSH in Remote Systems [message #575975 is a reply to message #24790] Thu, 17 July 2008 09:31 Go to previous message
You can:
Previous Topic:Custom port for SSH in Remote Systems
Next Topic:TCF on ARM
Current Time: Wed Apr 16 16:00:38 EDT 2025
Powered by FUDForum. Page generated in 0.03535 seconds
