Home » Eclipse Projects » Eclipse Platform » Plugin reload at runtime
Plugin reload at runtime [message #251787] Fri, 11 June 2004 09:54 Go to next message
Assume you have a plugin that is configurable in several ways. Some of
these configurations require that the code of the plugin is modified. Its
part of the plugins function to generate, compile and package the code
according to the configuration. Now it would be nice if the plugin could
automatically replace its jar file with the new version and use it.
Its similar to the features offered by the runtime-workspace, but I'd like
to have that for the "real" eclipse. I know I could generate the jar, end
eclipse, replace the jar, and restart eclipse. Then the plugin would be
loaded with the new code. What I want is exactly that, simply without
restarting eclipse.
Does anyone know whether this is possible, or how it is possible?
(I know that theoretically the code could be rewritten to fit every
configuration. Its not an option).
Thanks for help
Chris
Re: Plugin reload at runtime [message #252106 is a reply to message #251787] Sat, 12 June 2004 19:38 Go to previous message
Originally posted by: pascal.ibm.canada
I'm not sure I fully understood your question (you got me confused with
the part on the runtime-workspace :-), but I'll try an answer.
At a low level (from a runtime aspect), it possible to totally unload a
plugin. Of course a plugin can not unload it self. It needs to be done
by another plugin (probably the one taking care of the configuration).
If you want the unload to be successfull and more importantly don't leak
you need to restart all the plugins that depend on it.
To unload, you want to uninstall the plugin, then install the new
version and refresh it.
HTH,
PaScaL
> restarting eclipse.
> Thanks for help
> Chris
Previous Topic:How to publish a plug-in
Next Topic:EclipseStarter equivalent for BootLoader
Current Time: Thu Oct 16 06:41:38 EDT 2025
Powered by FUDForum. Page generated in 0.18702 seconds
