Configuring Eclipse to Point to JVM [message #251544] |
Thu, 13 March 2008 19:48 |
Originally posted by: khoohock.comp.nus.edu.sg
I copied to JDK 1.6 and it downloaded to the default directory ie.
d:\jdk1.1.6\bin. (This should be the correct version although I do not
know why it points to 1.1.6).
I subsequently pasted all the files downloaded to :
D:\Documents and Settings\Michael Khoo\My
Documents\Unzipped\eclipse-java-europa-winter-win32\eclipse\ jre\bin
which is where Eclipse expects the java executable files, dll files etc.
But when I run Eclipse I got a runtime error from the JVM with
termination code = 1.
Is there a way to configure Eclipse to point to the original directory the
JDK was downloaded ie. d:\jdk1.1.6\bin? Or what is the problem? Is there
anything I need to do to configure Eclipse properly?
Re: Configuring Eclipse to Point to JVM [message #251550 is a reply to message #251544] |
Thu, 13 March 2008 20:03 |
Michael wrote:
> Hi
> the JDK was downloaded ie. d:\jdk1.1.6\bin? Or what is the problem? Is
> there anything I need to do to configure Eclipse properly?
You should not copy files into the eclipse/jre directory; use
eclipse.ini instead. See this wiki page: http://wiki.eclipse.org/Eclipse.ini
Hope this helps,
Eric
Re: Configuring Eclipse to Point to JVM [message #251557 is a reply to message #251544] |
Thu, 13 March 2008 21:13 |
Hi Eric
I have amended my eclipse.ini file accordingly. I use the file from the
directory where my Eclipse has installed.
I still hit with the same error from the JVM module after executing with
terminated code = 1. My eclipse.ini contents are :
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256M
-vm
D:\jdk1.1.6\bin\javaw.exe
-vmargs
-Dosgi.requiredJavaVersion=1.6
-Xms40m
-Xmx512m
Actually I am not sure whether the java I downloaded is it 1.6 or 1.1.6?
My friend told me it should be 1.6 and the web page seems to give the
showing that 1.1.6 is the naming convention by highlighting in yellow only
the 1.6?
Eric can you help?
Thanks.
Michael
FUDForum. Page generated in 0.24811 seconds
