Home » Archived » BIRT » Problem starting BIRT 2.2 Engine
Problem starting BIRT 2.2 Engine [message #251122] Fri, 03 August 2007 11:27 Go to next message
Originally posted by: j.filimonova.spb.solidworks.ru
Hello!
I'm using BIRT 2.2 Engine API to render my report. Whole application is
running under JBoss 4.0.5. I try to start report engine from my JMX
MBean and I get a following error:
java.lang.NoSuchMethodError:
org.eclipse.birt.report.engine.api.EngineConfig.getLogger()L java/util/logging/Logger;
org.eclipse.birt.report.engine.api.impl.ReportEngine.intiali zeLogger(ReportEngine.java:108)
org.eclipse.birt.report.engine.api.impl.ReportEngine.<init>(ReportEngine.java:89)
org.eclipse.birt.report.engine.api.impl.ReportEngineFactory. createReportEngine(ReportEngineFactory.java:13)
com.swr.crm.as.report.ReportService.initializePlatform(Repor tService.java:189)
com.swr.crm.as.report.ReportService.startService(ReportServi ce.java:88)
Thanks in advance.
Re: Problem starting BIRT 2.2 Engine [message #251134 is a reply to message #251122] Fri, 03 August 2007 13:38 Go to previous messageGo to next message
Julia,
Are the versions of Java the same between the compiler and the JBoss
runtime?
Jason
Julia Filimonova wrote:
> Hello!
> at
> at
> at
> at
> at
> at
> Thanks in advance.
Re: Problem starting BIRT 2.2 Engine [message #251317 is a reply to message #251134] Mon, 06 August 2007 05:03 Go to previous message
I've already resolved the problem..
Yes, Jason, the versions of Java were the same.
But I had to copy BIRT jar files to /jboss_directory/lib/endorsed/
I hope it will be useful for somebody.
Jason Weathersby wrote:
> Julia,
> runtime?
> Jason
>> Hello!
>> is running under JBoss 4.0.5. I try to start report engine from my JMX
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks in advance.
Previous Topic:Manipulate data on rptdocument
Next Topic:Can't set JDBC parameter when using datasource obtained from JNDI
Current Time: Thu Apr 17 04:13:33 EDT 2025
Powered by FUDForum. Page generated in 0.05407 seconds
