Evolution of the CDT build environment...comments? [message #24694] |
Wed, 17 April 2002 14:17  |
Hi All,
Currently the CDT is built and packaged through the use of makefiles. This
has worked quite well for us, but is becoming clear that we need to revisit
this scheme. At the highest level, we have 2 build requirements:
REQUIREMENT #1 - Ability to build the CDT from within the Eclipse PDE
(Plugin Development Environment).
Ideally each of our plugins would contain the configuration files necessary
to build them with a minimum of user intervention. Any user should be able
to checkout our code from CVS, or use the source shipped with our releases
and be able to build the plugins without having to do much more than set a
variable or 2. Meeting this requirement should be a relatively simple matter
of setting up the CDT in the PDE and then making sure the generated
configuration files are generic enough for all users before checking them
in.
REQUIREMENT #2 - Ability to build the CDT from the command line (outside
eclipse).
This would be used by our nightly build process and users who prefer to work
with external editors and command line tools. While our makefile environment
is sufficient to build our code, it does not currently build the debugger
(com.ibm.debug) or the editor (com.ibm.lpex). Both of these components are
built by other teams who then provide us with packages containing jars and
zipped source. The builds of these components are NOT based on makefiles and
it is not reasonable for us to suggest that they now implement and support a
makefile based environment just for use in the CDT. Instead it appears that
the emerging "standard" for building plugins from the command line is Ant
(http://jakarta.apache.org/ant/).
So the proposal is that we move from a makefile based build environment to
an Ant-based one. I must confess that I have not yet used Ant but my survey
of the documentation indicates that all the function currently in our
makefiles could be easily reproduced as Ant tasks.
If there any readers who have any comments, we would love to hear them...
Thanks...
Jeff.
Re: Evolution of the CDT build environment...comments? [message #24737 is a reply to message #24694] |
Wed, 17 April 2002 15:00  |
Originally posted by: dominic.nospam.com
finally ...
"Jeff Turnham" <turnham@ca.ibm.com> wrote in message
news:a9kebs$mcr$1@rogue.oti.com...
> Hi All,
revisit
necessary
matter
> in.
> eclipse).
work
environment
and
a
that
survey
> Thanks...
> Jeff.
FUDForum. Page generated in 0.03879 seconds
