Home » Archived » BIRT » Sample DB & ReferenceError
Sample DB & ReferenceError [message #250576] |
Tue, 31 July 2007 17:10 |
Originally posted by: xxxx.xxx.com
Hello, I am using Birt 2.2 and noticed couple of things that I have nt
noticed in Birt 2.1.2.
1) When I start the report engine,I can see a sample database is created
in local drive. Is it necessary? If not,how can I avoid that.
2) When I run a report that is developed in 2.1.2, with the 2.2 Birt
engine, from a java application, I am getting an error:
SEVERE: ReferenceError: "dataSetParam" is not defined. (<inline>#1)
org.mozilla.javascript.EcmaError: ReferenceError: "dataSetParam" is not
defined.
(<inline>#1)
org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.jav
a:3240)
Why is that?
If any can shed some light on it, that would be really great.
Re: Sample DB & ReferenceError [message #250612 is a reply to message #250576] |
Tue, 31 July 2007 19:53 |
Kris,
if you do not want the sample db remove it from the plugins directory
and it will not show up anymore.
For the second issue can you post the report?
Jason
> defined.
> (<inline>#1)
> at
> a:3240)
> Why is that?
> Thanks
Re: Sample DB & ReferenceError [message #250642 is a reply to message #250612] |
Tue, 31 July 2007 20:31 |
--------------000709000309010201080908
Thanks Jason., I will try removing that.
For the second problem, I am attaching the report.
Jason Weathersby wrote:
> Kris,
> Jason
>> created in local drive. Is it necessary? If not,how can I avoid that.
>> not defined.
>> (<inline>#1)
>> at
>> a:3240)
>> Why is that?
>> Thanks
Content-Type: text/xml;
name="report.xml"
Content-Disposition: inline;
filename="report.xml"
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.6" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.1.1.v20060922-1058 Build <20060926-0959></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2006 <<Your Company Name here>></property>
<parameters>
<scalar-parameter name="RP_filetype" id="6">
<property name="valueType">static</property>
<property name="dataType">string</property>
<property name="allowNull">true</property>
<property name="controlType">text-box</property>
<property name="defaultValue">Email Files</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="RP_datestamp" id="7">
<property name="dataType">dateTime</property>
<property name="concealValue">false</property>
<property name="defaultValue">2007-05-25T00:00:00.000</property>
</structure>
</scalar-parameter>
<scalar-parameter name="RP_filecount" id="40">
<property name="dataType">integer</property>
<property name="defaultValue">1</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="4">
<property name="odaDriverClass">oracle.jdbc.OracleDriver</property>
<property name="odaURL">jdbc:oracle:thin:@host:1521:TableDB</property >
<property name="odaUser">Table</property>
<encrypted-property name="odaPassword">QTk2MjE2N</encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="Data Set" id="5">
<structure name="cachedMetaData"/>
<property name="dataSource">Data Source</property>
<list-property name="parameters">
<structure>
<property name="name">param1</property>
<property name="paramName">RP_filetype</property>
<property name="nativeName"></property>
<property name="nativeDataType">0</property>
<property name="position">1</property>
<property name="isOptional">true</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
<structure>
<property name="name">param2</property>
<property name="paramName">RP_datestamp</property>
<property name="position">2</property>
</structure>
<structure>
<property name="name">param3</property>
<property name="paramName">RP_filecount</property>
<property name="dataType">any</property>
<property name="position">3</property>
</structure>
</list-property>
<property name="queryText">select *
from Table
where filetypename = ? and datestamp < ?
and filecount > ?
order by datestamp</property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:name></design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>0</design:nativeDataTypeCode>
<design:nullability>Nullable</design:nullability>
<design:uiHints/>
</design:attributes>
<design:inputAttributes>
<design:elementAttributes>
<design:defaultScalarValue>Email Files</design:defaultScalarValue>
<design:optional>true</design:optional>
<design:masksValue>false</design:masksValue>
<design:uiHints>
<design:promptStyle>TextField</design:promptStyle>
</design:uiHints>
</design:elementAttributes>
</design:inputAttributes>
</design:parameterDefinitions>
<design:attributes>
<design:position>2</design:position>
<design:uiHints/>
<design:defaultScalarValue>2007-05-25T00:00:00.000</design:defaultScalarValue >
<design:uiHints>
</design:uiHints>
<design:attributes>
<design:position>3</design:position>
<design:uiHints/>
<design:uiHints>
</design:uiHints>
</design:DataSetParameters>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">0.1458333333in</property>
<property name="leftMargin">0.2291666667in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<grid id="12">
<property name="height">0.9895833333in</property>
<property name="width">7.0104166667in</property>
<column id="13"/>
<row id="14">
<property name="height">0.5104166667in</property>
<cell id="15"/>
</row>
<row id="16">
<property name="height">0.75in</property>
<cell id="17">
<table id="18">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<property name="name">FILETYPENAME</property>
<expression name="expression">dataSetRow["FILETYPENAME"]</expression >
</structure>
<structure>
<property name="name">DATESTAMP</property>
<expression name="expression">dataSetRow["DATESTAMP"]</expression>
<property name="dataType">date-time</property>
</structure>
<structure>
<property name="name">FILECOUNT</property>
<expression name="expression">dataSetRow["FILECOUNT"]</expression>
<property name="dataType">decimal</property>
</structure>
</list-property>
<method name="onCreate"><![CDATA[dataSetParam["param1"] = param["RP_filetype"];
dataSetParam["param2"] = param["RP_datestamp"];
dataSetParam["param3"] = param["RP_filecount"];]]></method>
<method name="onRender"><![CDATA[dataSetParam["param1"] = param["RP_filetype"];
<column id="31"/>
<column id="32"/>
<column id="33"/>
<header>
<row id="19">
<cell id="20">
<label id="34">
<text-property name="text">FILETYPENAME</text-property>
</label>
</cell>
<cell id="21">
<label id="36">
<text-property name="text">DATESTAMP</text-property>
</label>
</cell>
<cell id="22">
<label id="38">
<text-property name="text">FILECOUNT</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="23">
<cell id="24">
<data id="35">
<property name="resultSetColumn">FILETYPENAME</property>
</data>
</cell>
<cell id="25">
<data id="37">
<property name="resultSetColumn">DATESTAMP</property>
</data>
</cell>
<cell id="26">
<data id="39">
<property name="resultSetColumn">FILECOUNT</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="27">
<cell id="28"/>
<cell id="29"/>
<cell id="30"/>
</row>
</footer>
</table>
</cell>
</row>
</grid>
</body>
</report>
--------------000709000309010201080908--
Re: Sample DB & ReferenceError [message #250748 is a reply to message #250642] |
Wed, 01 August 2007 14:29 |
Kris
You have these lines in script
This should not be needed, because you are linking them in the dataset.
If you were changing them based on row values in the table you would use
the binding edior (binding tab on the table element) and select the
dataset parameter binding button.
Jason
> Thanks
>> Kris,
>> Jason
>>> nt noticed in Birt 2.1.2.
>>> not defined.
>>> (<inline>#1)
>>> at
>>> a:3240)
>>> Why is that?
>>> Thanks
> <parameters>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> from Table
> and filecount > ?
> <design:attributes>
> <design:uiHints/>
> <design:uiHints>
> </design:uiHints>
> <design:attributes>
> <design:uiHints/>
> <design:uiHints>
> </design:uiHints>
> <design:attributes>
> <design:uiHints/>
> <design:uiHints>
> </design:uiHints>
> </oda-data-set>
> </data-sets>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <grid id="12">
> <column id="13"/>
> <row id="14">
> <cell id="15"/>
> </row>
> <row id="16">
> <cell id="17">
> <table id="18">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <column id="31"/>
> <column id="32"/>
> <column id="33"/>
> <header>
> <row id="19">
> <cell id="20">
> <label id="34">
> </label>
> </cell>
> <cell id="21">
> <label id="36">
> </label>
> </cell>
> <cell id="22">
> <label id="38">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="23">
> <cell id="24">
> <data id="35">
> </data>
> </cell>
> <cell id="25">
> <data id="37">
> </data>
> </cell>
> <cell id="26">
> <data id="39">
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="27">
> <cell id="28"/>
> <cell id="29"/>
> <cell id="30"/>
> </row>
> </footer>
> </table>
> </cell>
> </row>
> </grid>
> </body>
> </report>
Re: Sample DB & ReferenceError [message #250750 is a reply to message #250748] |
Wed, 01 August 2007 14:34 |
Thanks Jason.
Just curious; may be this check they might have added new in 2.2 (The
report ran fine with 2.1)
Thanks again for the clarification.
> Kris
> Jason
>> Thanks
>>> Kris,
>>> Jason
>>>> not defined.
>>>> (<inline>#1)
>>>> at
>>>> a:3240)
>>>> Why is that?
>>>> Thanks
>> <parameters>
>> </structure>
>> </scalar-parameter>
>> <property
>> </structure>
>> </scalar-parameter>
>> </structure>
>> </scalar-parameter>
>> </parameters>
>> <data-sources>
>> <oda-data-source
>> id="4">
>> <property
>> <property
>> <encrypted-property
>> </oda-data-source>
>> </data-sources>
>> <data-sets>
>> <oda-data-set
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> from Table
>> and filecount > ?
>> <model:DesignValues
>> <design:attributes>
>> <design:uiHints/>
>> <design:uiHints>
>> </design:uiHints>
>> <design:attributes>
>> <design:uiHints/>
>> <design:uiHints>
>> </design:uiHints>
>> <design:attributes>
>> <design:uiHints/>
>> <design:uiHints>
>> </design:uiHints>
>> </oda-data-set>
>> </data-sets>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> <text-property
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <grid id="12">
>> <column id="13"/>
>> <row id="14">
>> <cell id="15"/>
>> </row>
>> <row id="16">
>> <cell id="17">
>> <table id="18">
>> <structure>
>> <property
>> <expression
>> <property
>> </structure>
>> <structure>
>> <property
>> <expression
>> <property
>> </structure>
>> <structure>
>> <property
>> <expression
>> <property
>> </structure>
>> </list-property>
>> <method
>> <method
>> <column id="31"/>
>> <column id="32"/>
>> <column id="33"/>
>> <header>
>> <row id="19">
>> <cell id="20">
>> <label id="34">
>> <text-property
>> </label>
>> </cell>
>> <cell id="21">
>> <label id="36">
>> <text-property
>> </label>
>> </cell>
>> <cell id="22">
>> <label id="38">
>> <text-property
>> </label>
>> </cell>
>> </row>
>> </header>
>> <detail>
>> <row id="23">
>> <cell id="24">
>> <data id="35">
>> <property
>> </data>
>> </cell>
>> <cell id="25">
>> <data id="37">
>> <property
>> </data>
>> </cell>
>> <cell id="26">
>> <data id="39">
>> <property
>> </data>
>> </cell>
>> </row>
>> </detail>
>> <footer>
>> <row id="27">
>> <cell id="28"/>
>> <cell id="29"/>
>> <cell id="30"/>
>> </row>
>> </footer>
>> </table>
>> </cell>
>> </row>
>> </grid>
>> </body>
>> </report>
Re: Sample DB & ReferenceError [message #250752 is a reply to message #250750] |
Wed, 01 August 2007 14:41 |
Kris,
2.2 added the binding editor I believe.
Jason
Kris wrote:
> Thanks Jason.
>> Kris
>> use the binding edior (binding tab on the table element) and select
>> the dataset parameter binding button.
>> Jason
>>> Thanks
>>>> Kris,
>>>> directory and it will not show up anymore.
>>>> Jason
>>>>> Birt engine, from a java application, I am getting an error:
>>>>> not defined.
>>>>> (<inline>#1)
>>>>> at
>>>>> a:3240)
>>>>> Why is that?
>>>>> Thanks
>>> <parameters>
>>> </structure>
>>> </scalar-parameter>
>>> <property
>>> </structure>
>>> </scalar-parameter>
>>> </structure>
>>> </scalar-parameter>
>>> </parameters>
>>> <data-sources>
>>> <oda-data-source
>>> Source" id="4">
>>> <property
>>> <property
>>> <encrypted-property
>>> </oda-data-source>
>>> </data-sources>
>>> <data-sets>
>>> <oda-data-set
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> from Table
>>> and filecount > ?
>>> <model:DesignValues
>>> <design:attributes>
>>> <design:uiHints/>
>>> <design:uiHints>
>>> </design:uiHints>
>>> <design:attributes>
>>> <design:uiHints/>
>>> <design:uiHints>
>>> </design:uiHints>
>>> <design:attributes>
>>> <design:uiHints/>
>>> <design:uiHints>
>>> </design:uiHints>
>>> </oda-data-set>
>>> </data-sets>
>>> <page-setup>
>>> <page-footer>
>>> <text id="3">
>>> <text-property
>>> </text>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <grid id="12">
>>> <column id="13"/>
>>> <row id="14">
>>> <cell id="15"/>
>>> </row>
>>> <row id="16">
>>> <cell id="17">
>>> <table id="18">
>>> <structure>
>>> <property
>>> <expression
>>> <property
>>> </structure>
>>> <structure>
>>> <property
>>> <expression
>>> <property
>>> </structure>
>>> <structure>
>>> <property
>>> <expression
>>> <property
>>> </structure>
>>> </list-property>
>>> <method
>>> <method
>>> <column id="31"/>
>>> <column id="32"/>
>>> <column id="33"/>
>>> <header>
>>> <row id="19">
>>> <cell id="20">
>>> <label id="34">
>>> <text-property
>>> </label>
>>> </cell>
>>> <cell id="21">
>>> <label id="36">
>>> <text-property
>>> </label>
>>> </cell>
>>> <cell id="22">
>>> <label id="38">
>>> <text-property
>>> </label>
>>> </cell>
>>> </row>
>>> </header>
>>> <detail>
>>> <row id="23">
>>> <cell id="24">
>>> <data id="35">
>>> <property
>>> </data>
>>> </cell>
>>> <cell id="25">
>>> <data id="37">
>>> <property
>>> </data>
>>> </cell>
>>> <cell id="26">
>>> <data id="39">
>>> <property
>>> </data>
>>> </cell>
>>> </row>
>>> </detail>
>>> <footer>
>>> <row id="27">
>>> <cell id="28"/>
>>> <cell id="29"/>
>>> <cell id="30"/>
>>> </row>
>>> </footer>
>>> </table>
>>> </cell>
>>> </row>
>>> </grid>
>>> </body>
>>> </report>
Re: Sample DB & ReferenceError [message #250844 is a reply to message #250750] |
Wed, 01 August 2007 21:55 |
Jason, on more thing I noticed while browsing through the log files is
that, the new 2.2 Engine throws an error as follows when trying to a report.
SEVERE: Message:The class
[org.eclipse.birt.report.engine.api.script.EngineScrip
tableClassInfo] can not be instantiated. Error
code:FAILED_TO_CREATE_INSTANCE
Could you please tell me what is going on?
Kris wrote:
> Thanks Jason.
>> Kris
>> Jason
>>> Thanks
>>>> Kris,
>>>> Jason
>>>>> not defined.
>>>>> (<inline>#1)
>>>>> at
>>>>> a:3240)
>>>>> Why is that?
>>>>> Thanks
>>> <parameters>
>>> </structure>
>>> </scalar-parameter>
>>> <property
>>> </structure>
>>> </scalar-parameter>
>>> </structure>
>>> </scalar-parameter>
>>> </parameters>
>>> <data-sources>
>>> <oda-data-source
>>> Source" id="4">
>>> <property
>>> <property
>>> <encrypted-property
>>> </oda-data-source>
>>> </data-sources>
>>> <data-sets>
>>> <oda-data-set
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> from Table
>>> and filecount > ?
>>> <model:DesignValues
>>> <design:attributes>
>>> <design:uiHints/>
>>> <design:uiHints>
>>> </design:uiHints>
>>> <design:attributes>
>>> <design:uiHints/>
>>> <design:uiHints>
>>> </design:uiHints>
>>> <design:attributes>
>>> <design:uiHints/>
>>> <design:uiHints>
>>> </design:uiHints>
>>> </oda-data-set>
>>> </data-sets>
>>> <page-setup>
>>> <page-footer>
>>> <text id="3">
>>> <text-property
>>> </text>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <grid id="12">
>>> <column id="13"/>
>>> <row id="14">
>>> <cell id="15"/>
>>> </row>
>>> <row id="16">
>>> <cell id="17">
>>> <table id="18">
>>> <structure>
>>> <property
>>> <expression
>>> <property
>>> </structure>
>>> <structure>
>>> <property
>>> <expression
>>> <property
>>> </structure>
>>> <structure>
>>> <property
>>> <expression
>>> <property
>>> </structure>
>>> </list-property>
>>> <method
>>> <method
>>> <column id="31"/>
>>> <column id="32"/>
>>> <column id="33"/>
>>> <header>
>>> <row id="19">
>>> <cell id="20">
>>> <label id="34">
>>> <text-property
>>> </label>
>>> </cell>
>>> <cell id="21">
>>> <label id="36">
>>> <text-property
>>> </label>
>>> </cell>
>>> <cell id="22">
>>> <label id="38">
>>> <text-property
>>> </label>
>>> </cell>
>>> </row>
>>> </header>
>>> <detail>
>>> <row id="23">
>>> <cell id="24">
>>> <data id="35">
>>> <property
>>> </data>
>>> </cell>
>>> <cell id="25">
>>> <data id="37">
>>> <property
>>> </data>
>>> </cell>
>>> <cell id="26">
>>> <data id="39">
>>> <property
>>> </data>
>>> </cell>
>>> </row>
>>> </detail>
>>> <footer>
>>> <row id="27">
>>> <cell id="28"/>
>>> <cell id="29"/>
>>> <cell id="30"/>
>>> </row>
>>> </footer>
>>> </table>
>>> </cell>
>>> </row>
>>> </grid>
>>> </body>
>>> </report>
Re: Sample DB & ReferenceError [message #250867 is a reply to message #250844] |
Thu, 02 August 2007 03:27 |
Kris,
I have not seen this error can you log it.
Jason
> report.
> Thanks
> Kris wrote:
>> Thanks Jason.
>>> Kris
>>> Jason
>>>> Thanks
>>>>> Kris,
>>>>> Jason
>>>>>> have nt noticed in Birt 2.1.2.
>>>>>> that.
>>>>>> is not defined.
>>>>>> (<inline>#1)
>>>>>> at
>>>>>> a:3240)
>>>>>> Why is that?
>>>>>> Thanks
>>>> <parameters>
>>>> </structure>
>>>> </scalar-parameter>
>>>> <property
>>>> </structure>
>>>> </scalar-parameter>
>>>> </structure>
>>>> </scalar-parameter>
>>>> </parameters>
>>>> <data-sources>
>>>> <oda-data-source
>>>> Source" id="4">
>>>> <property
>>>> <property
>>>> <encrypted-property
>>>> </oda-data-source>
>>>> </data-sources>
>>>> <data-sets>
>>>> <oda-data-set
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> </list-property>
>>>> from Table
>>>> and filecount > ?
>>>> <model:DesignValues
>>>> <design:attributes>
>>>> <design:uiHints/>
>>>> <design:uiHints>
>>>> </design:uiHints>
>>>> <design:attributes>
>>>> <design:uiHints/>
>>>> <design:uiHints>
>>>> </design:uiHints>
>>>> <design:attributes>
>>>> <design:uiHints/>
>>>> <design:uiHints>
>>>> </design:uiHints>
>>>> </oda-data-set>
>>>> </data-sets>
>>>> <page-setup>
>>>> <page-footer>
>>>> <text id="3">
>>>> <text-property
>>>> </text>
>>>> </page-footer>
>>>> </page-setup>
>>>> <body>
>>>> <grid id="12">
>>>> <column id="13"/>
>>>> <row id="14">
>>>> <cell id="15"/>
>>>> </row>
>>>> <row id="16">
>>>> <cell id="17">
>>>> <table id="18">
>>>> <structure>
>>>> <property
>>>> <expression
>>>> <property
>>>> </structure>
>>>> <structure>
>>>> <property
>>>> <expression
>>>> <property
>>>> </structure>
>>>> <structure>
>>>> <property
>>>> <expression
>>>> <property
>>>> </structure>
>>>> </list-property>
>>>> <method
>>>> <method
>>>> <column id="31"/>
>>>> <column id="32"/>
>>>> <column id="33"/>
>>>> <header>
>>>> <row id="19">
>>>> <cell id="20">
>>>> <label id="34">
>>>> <text-property
>>>> </label>
>>>> </cell>
>>>> <cell id="21">
>>>> <label id="36">
>>>> <text-property
>>>> </label>
>>>> </cell>
>>>> <cell id="22">
>>>> <label id="38">
>>>> <text-property
>>>> </label>
>>>> </cell>
>>>> </row>
>>>> </header>
>>>> <detail>
>>>> <row id="23">
>>>> <cell id="24">
>>>> <data id="35">
>>>> <property
>>>> </data>
>>>> </cell>
>>>> <cell id="25">
>>>> <data id="37">
>>>> <property
>>>> </data>
>>>> </cell>
>>>> <cell id="26">
>>>> <data id="39">
>>>> <property
>>>> </data>
>>>> </cell>
>>>> </row>
>>>> </detail>
>>>> <footer>
>>>> <row id="27">
>>>> <cell id="28"/>
>>>> <cell id="29"/>
>>>> <cell id="30"/>
>>>> </row>
>>>> </footer>
>>>> </table>
>>>> </cell>
>>>> </row>
>>>> </grid>
>>>> </body>
>>>> </report>
Current Time: Sun Oct 06 14:47:31 GMT 2024
Powered by FUDForum. Page generated in 0.05996 seconds
