simple cascading parameter question [message #250521] |
Tue, 31 July 2007 09:42 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: marcin.kierdelewicz.sitelynx.com
Hi BIRT specialists!
I have one question how not to display "NULL" value (as first) in
cascading parameters in BIRT?
Everytime I set it I receive NULL value as first entry.
Thank you for your help.
Best regards
Marcin Kierdelewicz
Re: simple cascading parameter question [message #250524 is a reply to message #250521] |
Tue, 31 July 2007 09:48 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
It is set to "is required" but fist position is allways empty with no
value (maybe it is something different than NULL in SQL"
Best regards
Marcin Kierdelewicz
> Best regards
> Marcin Kierdelewicz
Re: simple cascading parameter question [message #250630 is a reply to message #250524] |
Tue, 31 July 2007 20:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Marcin,
You need to set a default value if you do not want the first entry to
show blank.
Take a look at this simple report and notice the first one does have a
default value and the second does not.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.14"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.2.0.v20070620 Build <2.2.0.v20070626-1003></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 <<Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<parameters>
<cascading-parameter-group name="NewCascadingParameterGroup"
id="9">
<property name="dataSetMode">multiple</property>
<parameters>
<scalar-parameter name="ordernum" id="10">
<property name="valueType">dynamic</property>
<property name="isRequired">true</property>
<property name="controlType">list-box</property>
<property name="dataSetName">orders</property>
<expression
name="valueExpr">row["ORDERNUMBER"]</expression>
<property name="defaultValue">10101</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="prodcode" id="11">
<property name="dataSetName">orderdetails</property>
<expression
name="valueExpr">row["PRODUCTCODE"]</expression>
<property name="defaultValue"></property>
</structure>
</scalar-parameter>
</parameters>
</cascading-parameter-group>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="orders" id="7">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">ORDERDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">STATUS</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">COMMENTS</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">CUSTOMERNUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">STATUS</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">COMMENTS</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
</structure>
</list-property>
<property name="queryText">select *
from orders</property>
</oda-data-set>
<oda-data-set
name="orderdetails" id="8">
<structure>
</structure>
<structure>
<property name="name">PRODUCTCODE</property>
</structure>
<structure>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<list-property name="parameters">
<structure>
<property name="name">param_1</property>
<property name="paramName">ordernum</property>
<property name="nativeName"></property>
<expression name="defaultValue">10100</expression>
<property name="isOptional">false</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
</list-property>
<structure>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
from orderdetails
where ordernumber = ?</property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:name></design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:nullability>Unknown</design:nullability>
<design:uiHints/>
</design:attributes>
<design:inputAttributes>
<design:elementAttributes>
<design:defaultScalarValue></design:defaultScalarValue>
<design:optional>false</design:optional>
<design:masksValue>false</design:masksValue>
<design:dynamicValueChoices>
<design:dataSetDesign>
<design:name>orders</design:name>
<design:odaExtensionDataSetId>org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet </design:odaExtensionDataSetId>
<design:dataSourceDesign>
<design:name>Data Source</design:name>
<design:odaExtensionId>org.eclipse.birt.report.data.oda.jdbc </design:odaExtensionId>
<design:displayName></design:displayName>
<design:publicProperties>
<design:properties>
<design:nameValue>
<design:name>odaDriverClass</design:name>
<design:value>org.eclipse.birt.report.data.oda.sampledb.Driver </design:value>
</design:nameValue>
</design:properties>
<design:properties>
<design:nameValue>
<design:name>odaURL</design:name>
<design:value>jdbc:classicmodels:sampledb</design:value>
</design:nameValue>
<design:properties>
<design:nameValue>
<design:name>odaUser</design:name>
<design:value>ClassicModels</design:value>
</design:nameValue>
<design:properties>
<design:nameValue>
<design:name>odaPassword</design:name>
</design:nameValue>
<design:properties>
<design:nameValue>
<design:name>odaJndiName</design:name>
</design:nameValue>
<design:properties>
<design:nameValue>
<design:name>OdaConnProfileName</design:name>
</design:nameValue>
<design:properties>
<design:nameValue>
<design:name>OdaConnProfileStorePath</design:name>
</design:nameValue>
</design:publicProperties>
</design:dataSourceDesign>
<design:query>
<design:queryText>select *
from orders</design:queryText>
</design:query>
<design:properties>
<design:nameValue>
<design:name>queryTimeOut</design:name>
</design:nameValue>
<design:resultSets>
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERDATE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:attributes>
<design:name>REQUIREDDATE</design:name>
<design:position>3</design:position>
<design:attributes>
<design:name>SHIPPEDDATE</design:name>
<design:position>4</design:position>
<design:attributes>
<design:name>STATUS</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:attributes>
<design:name>COMMENTS</design:name>
<design:position>6</design:position>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>7</design:position>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:resultSets>
</design:dataSetDesign>
<design:enabled>true</design:enabled>
<design:valueColumn>row["ORDERNUMBER"]</design:valueColumn >
</design:dynamicValueChoices>
<design:uiHints>
<design:promptStyle>SelectableList</design:promptStyle>
</design:uiHints>
</design:elementAttributes>
<design:uiHints/>
</design:inputAttributes>
</design:parameterDefinitions>
</design:DataSetParameters>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<data id="12">
<list-property name="boundDataColumns">
<structure>
<property name="name">prodcode</property>
<expression
name="expression">params["prodcode"]</expression>
</structure>
</list-property>
<property name="resultSetColumn">prodcode</property>
</data>
</body>
</report>
> Best regards
> Marcin Kierdelewicz
>> Best regards
>> Marcin Kierdelewicz
Re: simple cascading parameter question [message #250696 is a reply to message #250630] |
Wed, 01 August 2007 08:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Dear Jason,
thank you for you answer.
I can't relly use default value in my case because I need to hide
somehow empty value not from the first parameter in cascading only in
others and I don't know what value they have because they are based on
first parameter value.
With reference to your example I would like to hide first empty position
in prodcode parameter.
Is it possible to enter in default value any expression or function that
displays first entry instead of empty row maybe?
Could you help me with this, please?
Thank you very much. I am really impressed with your knowledge. Every
solution you give always works!
Best regards
Marcin Kierdelewicz
Jason Weathersby wrote:
> Marcin,
> show blank.
> Jason
> id="1">
> <parameters>
> id="9">
> <parameters>
> <expression
> </structure>
> </scalar-parameter>
> <expression
> </structure>
> </scalar-parameter>
> </parameters>
> </parameters>
> <data-sources>
> <oda-data-source
> id="6">
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> from orderdetails
> <model:DesignValues
> <design:attributes>
> <design:uiHints/>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:query>
> </design:query>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:resultSets>
> <design:attributes>
> <design:attributes>
> <design:attributes>
> <design:attributes>
> <design:attributes>
> <design:attributes>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:uiHints/>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> <text-property name="content"><![CDATA[<value-of>new
> </text>
> </page-footer>
> </page-setup>
> <body>
> <data id="12">
> <structure>
> <expression
> </structure>
> </list-property>
> </data>
> </body>
> </report>
>> Best regards
>> Marcin Kierdelewicz
>>> Best regards
>>> Marcin Kierdelewicz
Re: simple cascading parameter question [message #250753 is a reply to message #250696] |
Wed, 01 August 2007 14:48 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Marcin,
Take a look at this modified example.
Both parameters start with a default value.
Jason
id="1">
<parameters>
id="9">
<parameters>
<expression
<property
name="defaultValue">firstparmdefault</property>
</structure>
</scalar-parameter>
<expression
<property
name="defaultValue">secondparmdefault</property>
</structure>
</scalar-parameter>
</parameters>
</parameters>
<data-sources>
<oda-data-source
id="6">
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</oda-data-set>
<oda-data-set
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
from orderdetails
<model:DesignValues
<design:attributes>
<design:uiHints/>
<design:properties>
<design:nameValue>
</design:nameValue>
<design:properties>
<design:nameValue>
</design:nameValue>
<design:properties>
<design:nameValue>
</design:nameValue>
<design:properties>
<design:nameValue>
</design:nameValue>
<design:properties>
<design:nameValue>
</design:nameValue>
<design:properties>
<design:nameValue>
</design:nameValue>
<design:properties>
<design:nameValue>
</design:nameValue>
<design:query>
</design:query>
<design:properties>
<design:nameValue>
</design:nameValue>
<design:resultSets>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:uiHints/>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<data id="12">
<structure>
<expression
</structure>
</list-property>
</data>
</body>
</report>
> Dear Jason,
> Best regards
> Marcin Kierdelewicz
>> Marcin,
>> show blank.
>> Jason
>> <?xml version="1.0" encoding="UTF-8"?>
>> version="3.2.14" id="1">
>> <parameters>
>> id="9">
>> <parameters>
>> <expression
>> </structure>
>> </scalar-parameter>
>> <expression
>> </structure>
>> </scalar-parameter>
>> </parameters>
>> </parameters>
>> <data-sources>
>> <oda-data-source
>> id="6">
>> <property
>> <property
>> </oda-data-source>
>> </data-sources>
>> <data-sets>
>> <oda-data-set
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </oda-data-set>
>> <oda-data-set
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> <property
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> <property
>> </structure>
>> </list-property>
>> from orderdetails
>> <model:DesignValues
>> <design:attributes>
>> <design:uiHints/>
>> <design:properties>
>> <design:nameValue>
>> </design:nameValue>
>> <design:properties>
>> <design:nameValue>
>> </design:nameValue>
>> <design:properties>
>> <design:nameValue>
>> </design:nameValue>
>> <design:properties>
>> <design:nameValue>
>> </design:nameValue>
>> <design:properties>
>> <design:nameValue>
>> </design:nameValue>
>> <design:properties>
>> <design:nameValue>
>> </design:nameValue>
>> <design:properties>
>> <design:nameValue>
>> </design:nameValue>
>> <design:query>
>> </design:query>
>> <design:properties>
>> <design:nameValue>
>> </design:nameValue>
>> <design:resultSets>
>> <design:attributes>
>> <design:attributes>
>> <design:attributes>
>> <design:attributes>
>> <design:attributes>
>> <design:attributes>
>> <design:attributes>
>> <design:uiHints>
>> </design:uiHints>
>> <design:uiHints/>
>> </oda-data-set>
>> </data-sets>
>> <styles>
Re: simple cascading parameter question [message #250757 is a reply to message #250753] |
Wed, 01 August 2007 17:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Dear Jason,
thank you for your example.
This is really what I was looking for.
You are the best BIRT expert!!!
Best regards
Marcin Kierdelewicz
> Marcin,
> Jason
> id="1">
> <parameters>
> id="9">
> <parameters>
> <expression
> <property
> </structure>
> </scalar-parameter>
> <expression
> <property
> </structure>
> </scalar-parameter>
> </parameters>
> </parameters>
> <data-sources>
> <oda-data-source
> id="6">
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> from orderdetails
> <model:DesignValues
> <design:attributes>
> <design:uiHints/>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:query>
> </design:query>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:resultSets>
> <design:attributes>
> <design:attributes>
> <design:attributes>
> <design:attributes>
> <design:attributes>
> <design:attributes>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:uiHints/>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <data id="12">
> <structure>
> <expression
> </structure>
> </list-property>
> </data>
> </body>
> </report>
>> Dear Jason,
>> position in prodcode parameter.
>> that displays first entry instead of empty row maybe?
>> Best regards
>> Marcin Kierdelewicz
>>> Marcin,
>>> show blank.
>>> a default value and the second does not.
>>> Jason
>>> <parameters>
>>> id="9">
>>> <parameters>
>>> <expression
>>> </structure>
>>> </scalar-parameter>
>>> <expression
>>> </structure>
>>> </scalar-parameter>
>>> </parameters>
>>> </parameters>
>>> <data-sources>
>>> <oda-data-source
>>> Source" id="6">
>>> <property
>>> <property
>>> </oda-data-source>
>>> </data-sources>
>>> <data-sets>
>>> <oda-data-set
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> <property
>>> </structure>
>>> </list-property>
>>> </oda-data-set>
>>> <oda-data-set
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> <property
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> <property
>>> </structure>
>>> </list-property>
>>> from orderdetails
>>> <model:DesignValues
>>> <design:attributes>
>>> <design:uiHints/>
>>> <design:properties>
>>> <design:nameValue>
>>> </design:nameValue>
>>> <design:properties>
>>> <design:nameValue>
>>> </design:nameValue>
>>> <design:properties>
>>> <design:nameValue>
>>> </design:nameValue>
>>> <design:properties>
>>> <design:nameValue>
>>> </design:nameValue>
>>> <design:properties>
>>> <design:nameValue>
>>> </design:nameValue>
>>> <design:properties>
>>> <design:nameValue>
>>> </design:nameValue>
>>> <design:properties>
>>> <design:nameValue>
>>> </design:nameValue>
>>> <design:query>
>>> </design:query>
>>> <design:properties>
>>> <design:nameValue>
>>> </design:nameValue>
>>> <design:resultSets>
>>> <design:attributes>
>>> <design:attributes>
>>> <design:attributes>
>>> <design:attributes>
>&g
FUDForum. Page generated in 0.04092 seconds
