Home » Archived » BIRT » BIRT Pre-requisites - is Eclipse SDK necessary?
BIRT Pre-requisites - is Eclipse SDK necessary? [message #250500] Tue, 31 July 2007 08:30 Go to next message
Originally posted by: pavel.kolesnikov.gmail.com
Hi all,
the BIRT download page lists the prerequisities as follows:
Java 1.5 JDK/JRE; Eclipse SDK 3.3, GEF 3.3, EMF 2.3, DTP 1.5, and WTP 2.0
We would like to give our users the smallest possible client distribution;
this is why I am concerned about the need for Eclipse SDK 3.3.
Do you have any idea about if it is really necessary, and if so, why?
Or could be Eclipse platform sufficient?
thanks a lot
Pavel
Re: BIRT Pre-requisites - is Eclipse SDK necessary? [message #250600 is a reply to message #250500] Tue, 31 July 2007 18:36 Go to previous messageGo to next message
Raishad is currently offline RaishadFriend
Member
Pavel Kolesnikov wrote:
> Hi all,
> thanks a lot
> Pavel
You can give them the RCP Designer
http://download.eclipse.org/birt/downloads/
It's the 3rd Download on the list. It's a essentially just the report
designer component with all the required components from Eclipse.
Re: BIRT Pre-requisites - is Eclipse SDK necessary? [message #250893 is a reply to message #250600] Thu, 02 August 2007 07:37 Go to previous message
>> thanks a lot
>> Pavel
Thanks, but unfortunately we need to distribute it together with
few other plugins providing an integration with our server-side apps.
This is why we need the plugin version rather than RCP.
By the way, if there is an RCP designer that obviously does NOT include
Eclipse SDK, perhaps the Report Designer plugin should work without it
too...
We'll try.
Pavel
Previous Topic:Simple Parameter Question
Next Topic:word emitter page break
Current Time: Sat Dec 21 14:43:03 GMT 2024
Powered by FUDForum. Page generated in 0.03457 seconds
